distributorless ignition for a TPI
Old 07-23-2004, 09:53 PM
TA Dreaming's Avatar
Just wondering if it is possible to run a distributorless ignition system on a TPI motor? Is there a kit or product availible to make this happen? Just thinking out loud really. Any info is appreciated. Thanks.
TA Dreaming is offline
Old 07-24-2004, 02:58 AM
Zepher's Avatar
Re: distributorless ignition for a TPI
Electromotive TEC-3 will eliminate the distributor and run a Cam or Crank (can't remember which) Position sensor and coil packs. $2300 for the complete system with harness, ECM, and related accessories.
Zepher is offline
Old 07-25-2004, 10:04 AM
FruityOne's Avatar
Just a little oh the high side for that system! I hope the ECM is on par with the latest DFI setup for tunability.
FruityOne is offline
Old 07-25-2004, 02:18 PM
Zepher's Avatar
It is one of the best ECMs for tuning. I am going to get this setup in a year or two. Can't afford it right now.
Zepher is offline
Old 07-25-2004, 04:47 PM
FruityOne's Avatar
I think I'll stick with my stock ECM for now. Thats one expensive setup. Though I suppose its not much more expensive than any current DFI setup either.
Old 07-25-2004, 10:43 PM
aklim's Avatar
If you really had to go DIS, why not just go for an LT1 complete with harness?
aklim is offline
G-BODYT56
01-14-2022 11:14 PM
93 RedBird
11-15-2015 08:24 AM
IndyZman
10-22-2015 02:17 PM
PopoFormula
10-12-2015 04:19 PM
Matt Dreessen
09-09-2015 09:58 PM
Quick Reply: distributorless ignition for a TPI
