Crank pulley bolts torque specs???
Old 06-01-2005, 10:21 PM
83TransAm's Avatar
What are the torque specs on a crank pulley bolt for a 350 sbc??? Also, what is the torque spec on the dampener bolt. I lost a crank pulley bolt and I believe the dampener bolt is loose (washer has play to it).
I bought a grade 5 bolt from a hardware store. The crank pulley bolts from an auto parts store were $9.00 as opposed to $.48 cents from a hardware store. Is a grade 5 strong enough???
Thanks!
83TransAm is offline
Old 06-02-2005, 01:31 AM
97WS6SCharged's Avatar
Re: Crank pulley bolts torque specs???
I'd get a good set of grade 8 bolts if it were me. I believe the torque is 50 ft/lbs for all the crank bolts.
97WS6SCharged is offline
Old 06-03-2005, 10:27 AM
Compstall's Avatar
Goodentite.
Compstall is offline
HectorM52
06-23-2016 08:42 PM
RUENUF
05-25-2016 08:10 PM
RUENUF
03-13-2016 03:39 PM
QuickSilver02
04-07-2015 11:12 AM
SpeedJunkee
01-27-2015 10:02 PM
Quick Reply: Crank pulley bolts torque specs???
