code?????
Old 10-16-2010, 12:42 AM
anthony22893's Avatar
code?????
22 tps sensor signal voltage low
throwing this code any ideas on what to do to fix this.
thanks
anthony22893 is offline
Old 10-17-2010, 03:07 PM
BigBadLou's Avatar
This code is thrown when the ECM sees low voltage on the TPS signal wire. It is usually caused by the blue wire grounding out (frayed wires by the sensor connector) or by the TPS itself being bad.
You can put a voltmeter on the blue wire on the TPS connector (connected to the TPS) with the key on and you should see cca 0.4V. You can then wiggle the wires or connector and see if the voltage drops lower (well, to 0V). You can also try to exercise the throttle blades several times, watching the voltage again. The voltage should never drop below 0.4V, that would point to a bad TPS.
You can google how to check the TPS, I'm sure you'll find a lot more detailed information than what I'm typing here in short.
Hope this helps.
Lou
BigBadLou is offline
Old 10-21-2010, 11:46 AM
thanks.
also at night when im driving with my lights on, my tach will stay at one spot and the turn signal light stays on i think something is shorting out what do yall think it is?
thanks
johnsocal
08-29-2002 10:01 AM
Darth Xed
14
08-07-2002 12:21 PM
91Bird305
13
08-05-2002 08:42 PM
91Bird305
08-05-2002 01:39 PM
BigDarknFast
07-08-2002 01:37 AM
Quick Reply: code?????
