which clutch for t56 in 2-piece main seal 350 block?
Old 04-20-2009, 01:44 AM
PowerAddict's Avatar
A buddy of mine is building a 383 for his 87 IROC. He picked up an old 4 main block, and also found a t56 to mate it with. What clutch and, more specifically, fly wheel does he need to do this?
Thanks.
PowerAddict is offline
Old 04-20-2009, 09:28 PM
86camaro383's Avatar
clutch dont matter...its the flywheel. RAM makes a aluminim one, and centerforce makes a steel one.
86camaro383 is offline
Old 04-21-2009, 01:32 PM
what would be the difference in the flywheels?
Old 04-22-2009, 12:17 AM
3rd Gen Tech Moderator
Kevin91Z's Avatar
A steel or iron flywheel gives you more inertia to get the car moving from a standstill like in drag racing.
An aluminum flywheel is lighter and turns easier at higher RPMs, for road racing and autocross.
Kevin91Z is offline
Old 04-22-2009, 06:50 PM
well, I guess, how will we know which flywheel is right. Like the actual difference between early model blocks flywheels, 2 piece blocks flywheels, and lt1 blocks flywheels?
Old 04-23-2009, 09:39 PM
early block and 2 piece RMS are the same, which are any block made 1985 and earlier. LT1 and and blocks made in 1986 and later are 1 piece RMS.
Rams aluminium one (which is the one I have, its a very nice piece) Jegs part number :798-2555
Centerforces one : 183-700173, thats a jegs part number as well. Those are 2 piece RMS flywheels.
The actual difference is the flanges it bolts up. http://www.thirdgen.org/techboard/tr...ap-thread.html
if you read the posts, youll find pics of what im talking about.
Old 04-27-2009, 11:09 AM
drptop70ss's Avatar
If he plans on using an LT1 T56 with the factory LT1 bellhousing and clutch he will need an adapter flywheel to work with the 2 piece RMS engine. It is an expensive piece but available through the aftermarket. If he is starting from scratch it would be cheaper to build a one piece RMS engine so he could use the factory LT1 flywheel..or use an LS1 T56 and an aftermarket bell to use the facotory 2 piece RMS flywheel, clutch, and mechanical linkage.
drptop70ss is offline
Old 04-28-2009, 04:40 PM
Yeah, he's got a 2 piece RMS block using an lt1 6 speed.
Old 05-20-2009, 05:16 PM
1 DWN CAM's Avatar
Mcleod makes a LT-1 flywheel with 2pc rear seal. PN-460370 for 0-balance and 460370-2C for external balance. This will only work with the "Pull Style" Valeo p/p and disc.
1 DWN CAM is offline
Old 06-20-2009, 11:37 AM
c1989rs's Avatar
http://www.summitracing.com/parts/RAM-2555/
this is the flywheel i am using and any t56 clutch will work i have a stage 3 clutch in mine depends on what u plan to do with it
c1989rs is offline
HectorM52
07-30-2017 11:46 AM
Magenta_Hearts
03-29-2017 08:54 PM
HectorM52
01-30-2015 11:08 PM
Quick Reply: which clutch for t56 in 2-piece main seal 350 block?
