Why is there a vent hole in the cap of the clutch master cylinder?
Old 04-24-2003, 11:49 AM
BLACK Z !'s Avatar
On the plastic container where the fluid is kept there is a little vent hole why? can mostiure canin there and ruin the brake fluid which is what is in the clutch master cylinder?
BLACK Z ! is offline
Old 04-30-2003, 10:59 AM
BLACK Z !'s Avatar
BTT
Old 05-01-2003, 07:13 PM
TheGreatJ's Avatar
The cap isn't actually what seals the reservoir. The black rubber cup that's under it is what seals it, and the vent hole is to keep the cup from building a vacuum which would prevent the master cylinder from pulling in the fluid that it needs. The brake reservoir has a similar diaphragm setup.
TheGreatJ is offline
Rod Bender
11-07-2023 02:30 PM
Rod Bender
05-16-2015 02:16 PM
timmy39120
05-02-2015 05:12 PM
Ringmaster72
03-19-2015 03:32 PM
Quick Reply: Why is there a vent hole in the cap of the clutch master cylinder?
