Cluster muck
Cluster muck
Took my dash apart to check on some gauges that weren't working... before, the temp and speedo weren't working...figured out that the speedo is the VSS...not worried...so i unstuck the temp gauge, which works now, but the tach, volts, gas, and oil pressure are not responsive anymore...and when i put my headlights on, the little "door ajar" noise hums pleasantly, non-stop, even with all the doors shut...what do i do?
