"clunk" when trying to crank,
Old 11-28-2009, 02:32 PM
sn8ke eatr's Avatar
starter makes a clunk sound, like the gear smacking the flywheel or something,
i replaced the starter and with all the plugs out it still does the same thing, any ideas?
wiring going to the starter all looks good,..
sn8ke eatr is offline
Old 11-29-2009, 03:12 PM
SupplySgt.'s Avatar
You sure the starter is spaced right? could be that it's not quite getting the gears all the way onto the flywheel.
SupplySgt. is offline
Old 11-30-2009, 03:44 PM
mdenz3's Avatar
Is the battery fully charged?
mdenz3 is offline
Old 11-30-2009, 04:58 PM
BigBadLou's Avatar
You are right, it's likely that the bendix is hitting the flywheel teeth and not engaging fully.
I'd remove the inspection cover and check it visually while engaging the starter (probably safer with disabled ignition and a remote switch). The starter would need to be shimmed then.
Lou
BigBadLou is offline
Old 12-02-2009, 07:34 PM
90rocz's Avatar
Did you turn the motor by hand to see if its locked up or binding?
90rocz is offline
Jeff1904
06-05-2016 05:00 PM
68camaroboltz
10-05-2015 11:56 PM
Ryan Ramsaran
09-19-2015 08:43 PM
95craz28
11
09-12-2015 07:47 AM
Aaront810
09-11-2015 11:24 AM
Quick Reply: "clunk" when trying to crank,
