"clunk" when trying to crank,
starter makes a clunk sound, like the gear smacking the flywheel or something,
i replaced the starter and with all the plugs out it still does the same thing, any ideas?
wiring going to the starter all looks good,..
You are right, it's likely that the bendix is hitting the flywheel teeth and not engaging fully.
I'd remove the inspection cover and check it visually while engaging the starter (probably safer with disabled ignition and a remote switch). The starter would need to be shimmed then.
Lou
Lou
68camaroboltz
10-05-2015 11:56 PM
Ryan Ramsaran
09-19-2015 08:43 PM
