Welcome to Camaro Z28!
Welcome to CamaroZ28.Com, the ultimate Source for Camaro enthusiasts! Here you can join over 90,000 Camaro enthusiasts from around the world discussing all things related to Camaros and more. You are currently viewing as a guest which gives you limited access to view discussions
To gain full access to our forums you must register for a free account. As a registered member you will be able to:
  • Participate in over 40 different forums and search/browse from over 5 million posts.
  • Upload your Camaro details to your Garage
  • Post photos, respond to polls and access other special features
  • Gain access to our free marketplace to buy, sell and trade Camaros, parts and more.
All this and much more is available to you absolutely free when you register for an account, so join our community today today!
If you have any problems with the registration process or your account login, please contact support.
Go Back   CamaroZ28.Com Message Board > 1967-2002 Powertrain Discussion > 3rd Gen / L98 Engine Tech
Sign in using an external account
Register Forgot Password?
Register Garage Photos Blogs FAQ Members List Social Groups Links Calendar Search Today's Posts Mark Forums Read Z28LiveVendor Directory TSBs
Reply Post New Thread
LinkBack Thread Tools Search this Thread Display Modes
Old 11-28-2009, 02:32 PM   #1
"clunk" when trying to crank,
starter makes a clunk sound, like the gear smacking the flywheel or something,
i replaced the starter and with all the plugs out it still does the same thing, any ideas?
wiring going to the starter all looks good,..
This ad is not displayed to registered members.
Register your free account today and become a member on CamaroZ28.com!
__________________
93' z/28 m6: under the knife
new combo coming together as we speak
sn8ke eatr is offline   Reply With Quote
Old 11-29-2009, 03:12 PM   #2
You sure the starter is spaced right? could be that it's not quite getting the gears all the way onto the flywheel.
__________________
73 Z-28: 350, TKO 600
98 Pontiac Grand Prix GTP (L67) RIP 11-5-09
Previous F-bodies 79 Z-28: 350, TH350, 87 IROC-Z: TPI 305, T5, 96 Camaro: L36, T5
SupplySgt. is offline   Reply With Quote
Old 11-30-2009, 03:44 PM   #3
Send a message via AIM to mdenz3
Is the battery fully charged?
__________________
-Mike D-
Quote:
Originally Posted by EKO View Post
AADD: Automotive Attention Deficit Disorder
Quote:
Originally Posted by notstock4long View Post
Holy **** you are stupid.
mdenz3 is offline   Reply With Quote
Old 11-30-2009, 04:58 PM   #4
Send a message via Yahoo to BigBadLou
You are right, it's likely that the bendix is hitting the flywheel teeth and not engaging fully.
I'd remove the inspection cover and check it visually while engaging the starter (probably safer with disabled ignition and a remote switch). The starter would need to be shimmed then.
Lou
BigBadLou is offline   Reply With Quote
Old 12-02-2009, 07:34 PM   #5
90rocz's Avatar
Did you turn the motor by hand to see if its locked up or binding?
__________________
1990 IROCZ, 1994 Z28-ASE Certified Auto Tech
"There is one rule for the industrialist and that is: Make the best quality of goods possible at the lowest cost possible, paying the highest wages possible."Henry Ford
90rocz is offline   Reply With Quote
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
Garage Plus vBulletin Plugins by Drive Thru Online, Inc.
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
