need help finding a cam
Old 11-24-2009, 11:03 AM
arodgers07's Avatar
im trying to put together a budget build right now for my 85 iroc and im looking for some advice on what cam would work best with my set up. i put in a gen 1 350 with an edelbrock 600 carb on an eps manifold. i just put on a pair of lightly ported 416 heads and a set of long tubes. the only other performance upgrade would be the flamethrower coil and distributor. i looking to get a cam with good duration and lift. sense the motor has high compression its got torque, im looking for something thats going to help those heads breathe a little easier throughout the rpm range but more so on the top end. i still want to be able to take the car out on the road sometimes so it cant be to extreme but still needs to have that choppy idle. i kno im askin a lot but any help would be nice. and if you can estimate what kind of numbers im might see at the wheels with this set up would be good to.
arodgers07 is offline
Old 12-02-2009, 07:45 PM
90rocz's Avatar
Comp Cams 258 if more street or 268 if more performance ...they have several varieties...good idle strong mid range and improved top end.
Best all around cams ever!
90rocz is offline
AdsoYo
05-02-2018 03:21 AM
HectorM52
07-30-2017 11:46 AM
pimpss96
02-12-2015 01:28 PM
chuyz28
01-15-2015 04:14 PM
Brandon Wittmer
12-20-2014 09:51 PM
Quick Reply: need help finding a cam
