Cleaning MAF 87 Z28 Question
Hey Guys,
Is it possible to remove the screans on the MAF or a 87 TPI? I've used the CRC cleaner but the front of the resistive wires are dirty and the backside of the wires are bright silver, so I don't know if it's doing it's trick. How would the screen be removed for cleaning?
the MAF has a self cleaning system built in. after the car has been running, after you shut it off the burn off relay kicks in and heats the wires red hot and then goes out. this burns all of the impurities off the sensor wires.
