check engine light
check engine light
my 91 camaro 5.7, engine light comes on when i start it and will go away when it warms up. but after that it will come on and off randomly. the car runs like crap when its on, but when it goes off it acts like nothing is wrong. i thought it was my O2 sensor so i changed it but it didnt help. anyone know why it does this?
i have-
gutted air box
jet stange 2 chip
air foil
after market magnaflow cats with the AIR not hooked up.
cat back exhaust
i have-
gutted air box
jet stange 2 chip
air foil
cat back exhaust
If you use a metal paper clip in the top right holes of the port, with the car off, turn the key to on. The SES light will flash 1 beat...then 2 beats. That is code 12. It will do that 3 times. Then it will flash the first real code. Whatever it will be, again 3 times. Depending if you have more than one code, it will then reflash code 12 telling you that is all the codes.
It seriously takes less than a minute. I love obd1 for that, you don't need a scanner to see whats going on with the car.
Get the flash code sequence, look it up on thirdgen.org and get back with us.
heck you can even use a staple to jump the ports. as long as it's long enough to reach and it's metal then you'll be able to pull the codes that way. If you get us the codes we'll have a much easier time pointing you in the right direction
He pulled the code and got responses a while back:
https://www.camaroz28.com/forums/sho...d.php?t=682087
https://www.camaroz28.com/forums/sho...50#post5930750
01-05-2015 07:14 PM
