Carb and HEI recommendation for a 350 5 Speed Combo
Hi, I currently have the electronic Q Jet on the car, I have a Gm 350 along with a 5 Speed, My other mods are in my Sig Below, Just wondering what carb is recommended, It is not a daily driver but I am looking for a good reliable carb,I am also looking for an HEI Dist to go along with it.
By Changing the Carb and Dist is there anything else I need to do? can I just take the Check engine bulb out and worry about it after this?
Re: Carb and HEI recommendation for a 350 5 Speed Combo
have you ever thought about stepping up to injection? with you ready to make an upgrade the FAST ez EFI would be a great move. self tuning, built in wide band, able to change setup when you build a bigger motor.
Spoke to Holley and they Recommended the 600 CFM Double Pumper, Or the 650 DP.
As far as DIST go Should I go in cap Coil ( HEI ) or Separate Coil/Dist?
Do I need a adjustable Vac advance or not?
Well I ordered these today, hope I made a good choice.
Holley Performance Products 650 CFM Ultra Double Pumper™ Four Barrel Street/Strip Carburetor - Black™ 0-76650BK
MSD Pro-Billet HEI Distributors 8365 - SummitRacing.com
If your car runs well - no issue with the carb, leave it alone.
You can easily tune the carb for a larger motor with more power - it will support 500hp with the right fuel system.
