Welcome to Camaro Z28!
Welcome to CamaroZ28.Com, the ultimate Source for Camaro enthusiasts! Here you can join over 90,000 Camaro enthusiasts from around the world discussing all things related to Camaros and more. You are currently viewing as a guest which gives you limited access to view discussions
To gain full access to our forums you must register for a free account. As a registered member you will be able to:
  • Participate in over 40 different forums and search/browse from over 5 million posts.
  • Upload your Camaro details to your Garage
  • Post photos, respond to polls and access other special features
  • Gain access to our free marketplace to buy, sell and trade Camaros, parts and more.
All this and much more is available to you absolutely free when you register for an account, so join our community today today!
If you have any problems with the registration process or your account login, please contact support.
Go Back   CamaroZ28.Com Message Board > 1967-2002 Powertrain Discussion > 3rd Gen / L98 Engine Tech
Sign in using an external account
Register Forgot Password?
Register Garage Photos Blogs FAQ Members List Social Groups Links Calendar Search Today's Posts Mark Forums Read Z28LiveVendor Directory TSBs
Reply Post New Thread
LinkBack Thread Tools Search this Thread Display Modes
Old 06-04-2010, 10:04 PM   #1
Car turns over but won't start
I'm new here trying to get a 1987 Iroc back on the road.I know it ran when it was parked a few years ago . Now it will turn over but will not start. also see that the check engine light is on. Any help on what to check or do would be great. Looking for a place to start on this problem. I do see spark at the plugs.
This ad is not displayed to registered members.
Register your free account today and become a member on CamaroZ28.com!
Z28GARAGE is offline   Reply With Quote
Old 06-05-2010, 08:14 AM   #2
under the dash at your right knee cap is a plug. take a paperclip and bend it into a U shape. you want to put the clip in the A and B terminals. this will be the upper 2 right holes in this plug.
one leg of the clip goes in each hole. then turn the key to the on pos but DONT START. your check eng light will start flasshing a code 12, this is ok because its telling the ECM its not getting a spark sig. disregard this code. it will flas 1 and then 2 flashes. it will do this 3 times then move to the next code.
write each code down and when it returns back to code 12. go to thirdgen.org and they have a listing of codes to tell you whats going on.
as for no turnover. yank plug wire off, stick a screwdriver in the cap, hold it to the strut screws but dont touch. have someone turn the car over and if you get a spark. if you dont then it might be your ign module.
__________________
Richard
89 formula LB9 WS6 T-5
83 T/A 350 T-5
run it wide open till ya see god "THEN" brake !
quickchicken is offline   Reply With Quote
Old 06-05-2010, 02:23 PM   #3
Thanks, I'll give it a try.
Old 07-23-2010, 11:07 AM   #4
GRIDERMAN87's Avatar
If you have spark, that means you probably have a fuel problem, check to see if the pump is priming
__________________
96 Z28--T-tops, t56, 4.11's, cold air, true duals, JBA mid lengths, not cats, no egr, lt4 hot cam, bbk twin 52 TB, madz28 tune, it'l run
GRIDERMAN87 is offline   Reply With Quote
Old 08-05-2010, 03:12 PM   #5
Drain the fuel and put new gas in before you gum the fuel system up with that old gas. Thats prolly the issue and you should change the fuel filter too.
fbody93 is offline   Reply With Quote
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
Garage Plus vBulletin Plugins by Drive Thru Online, Inc.
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
