Welcome to Camaro Z28!
Welcome to CamaroZ28.Com, the ultimate Source for Camaro enthusiasts! Here you can join over 90,000 Camaro enthusiasts from around the world discussing all things related to Camaros and more. You are currently viewing as a guest which gives you limited access to view discussions
To gain full access to our forums you must register for a free account. As a registered member you will be able to:
  • Participate in over 40 different forums and search/browse from over 5 million posts.
  • Upload your Camaro details to your Garage
  • Post photos, respond to polls and access other special features
  • Gain access to our free marketplace to buy, sell and trade Camaros, parts and more.
All this and much more is available to you absolutely free when you register for an account, so join our community today today!
If you have any problems with the registration process or your account login, please contact support.
Go Back   CamaroZ28.Com Message Board > 1967-2002 Powertrain Discussion > 3rd Gen / L98 Engine Tech
Sign in using an external account
Register Forgot Password?
Register Garage Photos Blogs FAQ Members List Social Groups Links Calendar Search Today's Posts Mark Forums Read Z28LiveVendor Directory TSBs
Reply Post New Thread
LinkBack Thread Tools Search this Thread Display Modes
Old 04-12-2010, 11:14 PM   #1
Car dies at wide open throttle
Just took my car out of storage about 2 weeks ago. It's an 1989 firebird formula 350 with 71000 miles on it. When I'm going about 20mph and I stomp on the gas, the car will down shift to first gear like it should and then it dies out. It only does this while I'm already moving and with the head lights on. If I drive during the day, the lights are off and there is no problem. If the lights are on and I stomp on it from a dead stop there is no problem. When the car dies out there is no Service Engine Soon light. There is no problem at higher speeds when the car down shifts to 2nd gear.
Just to be clear, the car dies out only when the head lights are on, and the car down shifts to 1st gear at 20mph.
This ad is not displayed to registered members.
Register your free account today and become a member on CamaroZ28.com!
__________________
1989 Firebird Formula, 305 TBI, auto, 100% stock
1989 Firebird Formula, 350 TPI, auto, 100% stock
1991 Camaro Z-28, 350 TPI, auto, 100% stock
2001 Camaro SS, LS1, auto, 100% stock
cars3 is offline   Reply With Quote
Old 04-14-2010, 10:33 PM   #2
Well, the car is still doing the same thing, but now I'm getting a service engine soon light and I checked it with my scanner and I'm getting a code 34 which is Mass air flow sensor. I pulled it out and every thing looks good. I know they cost some coin because I put one in my old iroc-z and it was like $240 for a new one from GM about 10 years ago. Any electrical checks (OHM checks ) that can be done on the sensor to prove it's bad.
__________________
Old 04-14-2010, 11:11 PM   #3
Super Moderator
Garage
Let's move this to "3rd Gen/L98 Engine Tech", where you might get some help.
__________________
Fred
94 Formula A3+1: 381ci all-forged stroker - Callies Stealth, Oliver 5.85 billet rods, BME nitrous pistons/CNC LT4 heads/Comp Cams custom solid roller/TH400+GearVendors OD/4.11's/Strange 12-bolt/300-shot N2O/Spohn Suspension/6-pt roll bar with integrated SFC's/full AutoMeter instrumentation/MoTeC M48 Pro engine management system/a few other odds 'n ends.
My website is down. Hopefully, links/photos be restored in 2 or 3 weeks.
Injuneer is offline   Reply With Quote
Old 04-15-2010, 09:54 AM   #4
Can you swap one from another car that is running fine?
I see you have another Firebird, thats why I asked.
__________________
2000 Camaro SS A4 # 3535,milled LS6 heads (to 62cc's) with Cometic .045,custom 230/236 .591/.600-112 cam,Hooker LT's with TSP catted Y,LS6 intake,3400 Vig. stall
'86 IROC-Z clone race car, 565/TH400 5.68@120 off early and on the brakes
Rice Killer87 is offline   Reply With Quote
Old 04-15-2010, 10:54 PM   #5
Quote:
Thanks for moving. Sometimes it can be hard to decide where to post.
__________________
Old 04-15-2010, 10:56 PM   #6
No, my 350 firebird is TPI which uses a mass air flow sensor, and my other firebird is a TBI which uses a Map sensor and so does my 91 camaro with a 350.
__________________
Old 04-26-2010, 09:25 PM   #7
byrons1502's Avatar
Is it still doing it
__________________
1969 chevelle ss396 now doing frame off. pro touring style. Going with turbo 5.3ltr
1989 C1500 4.3ltr going to a 5.3ltr turbo also,
ASE MASTER CERTIFIED,L1 & X1
byrons1502 is offline   Reply With Quote
Old 04-26-2010, 11:00 PM   #8
Quote:
As of Saturday night, yes it was still doing it. Only at 20mph or close to that and when the gas pedal is pushed all the way to the floor and right after it shifts into 1st gear. Only when the head lights are turned on which I can't make the connection between the two.
__________________
Old 04-28-2010, 11:25 PM   #9
does it do it with the parking lights on with(no headlights)?
gtadude is offline   Reply With Quote
Old 04-29-2010, 12:18 AM   #10
Quote:
I don't know. I never thought of trying that. I'll check it out this weekend and see what happens.
__________________
Old 04-29-2010, 01:24 PM   #11
You might also check your amp draw with the lights, radio,flashers on. You might also have a bad ground. I know it my sound silly but I also had a similar issue years ago with my Chevelle and it turned out to be a a dirty ground connection.
Fishingted is offline   Reply With Quote
Old 04-29-2010, 11:54 PM   #12
Quote:
Thanks, a few more things to check this weekend. However the weather forcast is rain for the weekend and I really don't like taking the car out in the rain.
__________________
Old 05-17-2010, 10:54 PM   #13
byrons1502's Avatar
well what happened. any more info
__________________
Old 05-21-2010, 11:09 PM   #14
Sorry, been very busy doing yard work and have not been on the computer in a while. I've been driving it the last few days to work, and I have not had a problem with it. Everything seems to be normal. But, this is only temporary like most problems, I'm sure it will come back.
__________________
Old 05-22-2010, 12:58 PM   #15
im gonna throw this out there and hope it lands you on a fix.
my 89 formula had a headlight issue once. i was going to a friends place that does local fab of F stuff like SFCs and such. for what ever reason my switch started buzzing so i pulled over and checked things out. everything seemed normal so i went and again as i hit the rumblers on the shuolder they acted up again. finally i gave, the lights gave me a break and i went home.
bout a year later i had a wper issue. thought i had a weird surge and it poped a fuse so i replacd it no biggie. shortly later it did it again so i replaced it 2 more times and gave up. luckily i had much rain x on the windo so i had no issues.
going home that day the lights acted up again as i was almost home. i backed the car in the drive and ripped the dash apart. after i had the switch dangling i went underside to see what i could find. with the fuse block pulled down, head in the floorboard and feet in the headrest i started poking around. dunno what told me to but i rolled this hue chunk of harness around that is just right of the fuse block as your looking up under the dash.
lo and behold there were 4 wires that had the insulation rubbed off from the lower dash support bracket that is next to the fuse block. check this area and see if you have something similar going on.
__________________
Richard
89 formula LB9 WS6 T-5
83 T/A 350 T-5
run it wide open till ya see god "THEN" brake !
quickchicken is offline   Reply With Quote
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
Garage Plus vBulletin Plugins by Drive Thru Online, Inc.
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
