bolt pattern on 92 camaro z28???help
Old 04-09-2003, 08:33 PM
ram air camaro's Avatar
i thought id ask you guys since you guys own this cars, me and my friend are planning on sharing rims for drags tires, he owns a 92 camaro z28 tpi, and i own a 94 camaro z28 lt-1, i waS wondering if its the same bolt pattern, hopfulley they are? what do you guys think?
ram air camaro is offline
Old 04-09-2003, 09:41 PM
mrr23's Avatar
yes they are. always have been since 1967.
mrr23 is offline
Old 04-10-2003, 01:06 AM
do you know the bolt pattern are they all the same?
Old 04-10-2003, 01:15 AM
irocbob89's Avatar
Yes, your bolt pattern is the same, you just have to watch to mach sure the rims dont rub the calipers/drums. I put some SS rims on my 89 iroc WITH OUT spacers and they rubed my calipers, eeehhh good thing they werent my rims, i let a guy with a 97 SS use my slicks for a few runs and i was going to run his street tires. Well he got to run but i didnt. Good luck with yours though.
irocbob89 is offline
Old 04-10-2003, 02:30 AM
thanks for the answers, i apreciate that
Old 04-10-2003, 07:59 AM
caspergotaz28's Avatar
The bolt pattern is the same for the 3rd and 4th gen but the required offset if very different.
The 3rd gen will require a wheel with an off set of around 0mm. While the 4th gen needs an offset in the 50-60mm range.
For example, a 4th gen rim will not bolt directly onto a 3rd gen. You have to utilize spacers.
However a 3rd gen rim will bolt on a 4th gen, but the wheel will stick out past the fender lip about 2-3"
What type of rims were you planning on using? Stock 3rd or 4th gen rims? Aftermarket rims? What are the specs on it? Rim width, diameter, offset, backspacing?
caspergotaz28 is offline
Old 04-10-2003, 04:17 PM
stock third gen! any body selling some
Old 04-10-2003, 09:27 PM
mrr23's Avatar
yep. i have run tires stores for quite awhile. GM has never changed the bolt pattern on the fbody. only the back spacing as the years went by. the bolt pattern is 5 x 4.75 meaning 5 lug 4.75" bolt circle
mrr23 is offline
Old 04-14-2003, 02:09 PM
thanks
Old 04-15-2003, 10:47 AM
irocz8957's Avatar
yeah they should always be same but i know you can't take wheels off of a 4th gen and put them on 3rd gen or vice versa
irocz8957 is offline
Old 04-15-2003, 06:35 PM
mrr23's Avatar
you cna put 3rd gen on 4th gen. they will stick out about 2" though. to put 4th gen on a 3rd, you'll need 2" adapters from www.skulte.com
mrr23 is offline
CamaroHeed
03-18-2020 09:50 PM
Brandon Wittmer
12-03-2014 09:28 PM
grendal
04-15-2010 05:20 PM
2000silverz28
07-20-2002 06:14 AM
Quick Reply: bolt pattern on 92 camaro z28???help
