Big Block in 3rd gen?
Old 07-10-2002, 03:17 PM
SNEAKY NEIL's Avatar
Post Big Block in 3rd gen?
Is this possible? My friend was kind of thinking out loud and came up with putting a Ram-jet 502 in a 92' RS that he saw for sale at a good price. Can this large a motor fit in the engine bay and can the car be mated to a T56? He nor I know anything about this kind of venture so any info on the possibility of this would be great. Thanks.
SNEAKY NEIL is offline
Old 07-10-2002, 03:18 PM
88 427 Camaro's Avatar
Post
All the info from my 427 swap is on my page at www.koolmeister.com
Miles
88 427 BBC Camaro
7.76 @ 94 (1/8 mile) 10/01
12.18 @ 113 (1/4 mile) 10/99
I have brand new series 3 9 bolt posi carriers and gear sets to 4.10 available for borg warner 9 bolts. Check my web page for more info.
http://www.koolmeister.com
88 427 Camaro is offline
Old 07-11-2002, 12:15 PM
Post
Anyone else?
Old 07-11-2002, 02:21 PM
RedIrocZ-28's Avatar
Post
Well, you will need to do EXTREME frame reinforcement if you want my opinion. Sub-frame connectors are a must and I'd probably put a roll cage in also. The motor I plan on is just a SBC and the guy who did a lot of my engine work on the most recent motor claimed he did basically what I did but he didn't have subframes or anything and he twisted the car in half. So Big blocks are a pain because of all the other crap you need to do like what I already mentioned and a new rearend like a 9" or a 12 bolt etc. etc... um There is a lot of stuff to do which I believe is pretty well laid out in the link posted by 88 427 Camaro.
RedIrocZ-28 is offline
Old 07-11-2002, 04:30 PM
1989gta's Avatar
Post
hooker makes long tube headers for that aplication so people have done it. Almost order them by mistake thinking i could get larger primarys than 1 3/4's
1989gta is offline
Old 07-11-2002, 08:24 PM
Stephen 87 IROC's Avatar
Post
You don't "need" a 9" or a 12 bolt but it helps. I was running a beefed up 7.5" 10 bolt last year. I only switched to a 9" because I changed trannys, went to a very high stall converter and installed a transbrake. I didn't think the little 7.5" ring and pinion would have lasted with the new combination.
Stephen's racing page
or check out the race car
87 IROC SuperPro race car
461 big block
Best ET on a time slip: 11.589
Best MPH on a time slip: 115.91
Best corrected ET: 11.114
Altitude corrected rear wheel HP: 457
Best 60 foot: 1.646
Member of the Calgary Drag Racing Association
Stephen 87 IROC is offline
Old 09-08-2014, 12:44 PM
couchmotors's Avatar
Re: Big Block in 3rd gen?
Miles
88 427 BBC Camaro
KOOLMEISTER.COM
Im currently . Installing a 496 in my 91 rs. I took out the computer side of the harness. What do i need to do to get the speedo to work and what do i need to do to make sure the fuel pump works when i go to fire it up.. I have the harness out of the car. I left eveything on the driver side . It is a v-6 harness 3.1
couchmotors is offline
Old 09-09-2014, 10:45 AM
88 427 Camaro has not returned to this site in more than 9 years. You may want to try an e-mail. Left click on the screen name, and there is a "send an e-mail option" on the dropdown.
Injuneer is offline
MadMav
02-06-2015 11:02 PM
RedLineRev
01-23-2003 03:51 PM
Skull Leader
08-10-2002 11:01 AM
Eric H
08-10-2002 06:39 AM
Doug Harden
11
07-14-2002 04:31 PM
Quick Reply: Big Block in 3rd gen?
