I replaced my IROC 383 TPI struts with Lakewoods, the springs with Moroso trick springs, and the ball joints while I was at it. If his ride has over 100,000 like most third gens do he should replace them.
I also put a 3 core radiator in,Hayden cooling fan,160º thermostat. Also make sure the lower airdam is in place as that makes a big difference in cooling these cars down. (My engine temp. doesn't get above 180º even on the really hot days, and the cooler days it runs about 165-170º)
