ball joint replacement
http://www.fl-thirdgen.org/balljointreplacement.html
here's how i do it.for you guys that have been asking how.
fl-thirdgen.org#0004
moderator @ www.fl-thirdgen.org '86 t/a, 3.27, auto, homemade CAI, hypertech AFPR, comp cams 1.52 roller tip rockers, holley prostrip annililator ignition system, shift kit,
OEM corvette 2100 rpm convertor, lakewood adjustable panhard rod and trailing arms, edelbrock 6872 headers, catco 6007 3" cat, flowmaster 17151 3" single outlet catback. 14.91 @ 90.57 177.7rwhp 356.4rwtq
I pressed mine in using my 20 ton Hyd press. I don't like beating on my car to install parts. Easy does it is always best, if you don't have a press pay to have it done. My press cost about 200.00 at Northern but I use the heck out of it. BTW if you notice the install inside label is for a grease pressure relief. Install inside to keep grease off the rotor. I've never seen one releave there but you never know I guess.
92BLKL98
'92 Black Z28 Hardtop w/Harwood 2" cowl ind. hood, Modded 700R4, MSD
Ignition, March Underdrives, TPIS Fastpak, Ram air w/gutted filter box, SLP Prom, Flowmaster, & free mods, removed cats, Amsoil synthetic lubes, CE SFC's, Edelbrock STB,Spohn TA,Roadtech LCA's and Panhard Rod, Energy Susp., PST polygraphite bushings, KYB Shocks.
92BLKL98
now i know what it's for. i'll change the page to reflect that.
Carogna'sZ-28
02-03-2015 07:04 PM
