700R4 TV cable on 6-71 blower????
Hello all, been lurking for a few months and need to ask if anyone has ever used a 700R4 and a 6-71 blower. Obviously it's a street cruiser that needs an OD trans. It's a 86 Chevy pickup with a 454 BBC. I just need to figure a way to connect the TV cable to one of the Holley 4150s which set sideways on the top of the blower.
Thanks in advance.
Thanks in advance.
Re: 700R4 TV cable on 6-71 blower????
I think you just need a longer cable. have you tried "Lokar". http://www.jegs.com/vpt/Lokar/Auto-Trans-Kick-Down
Yes, I figured if all else failed we could go that route. But was hoping someone had found a way to connect the cable to the back carb on the choke side of the carb. There just isn't enough room to get more linkage between the carbs.
I also wondered if anyone had connected to the lower linkage that the throttle connects too.
