91 z28 firing order - CamaroZ28.Com Message Board
Reply
Thread Tools Search this Thread
Old 03-01-2007, 01:39 PM   #1
91 z28 firing order
ok i know the firing order but don't know which is which so if anyone could get me a pic linked so i can see the distruberter cap and which cylinders are which it would help i believe that i have 2 crossed any help would be nice.
z28camaro095 is offline   Reply With Quote
Old 03-01-2007, 01:42 PM   #2
the prong facing the front(or closest) is generally for #1, then just count around clockwise.
confused327 is offline   Reply With Quote
Old 03-01-2007, 02:16 PM   #3
spin ur crank to top dead center for cylinder one then remove the cap and take note of the position of the rotor
there are a few ways to tell if your crank is at tdc for cylinder one
you may have markings on your harmonic balancer
you could remove the number one spark plug and stick something in there to feel the piston (dont use the starter motor to spin the crank for this method)
respectirocz is offline   Reply With Quote
Old 03-01-2007, 04:08 PM   #4
When facing the engine from the front of the car the right cylinder bank (driver's) from front to back is 1-3-5-7 and the left bank (pass) is 2-4-6-8. Along with the info confused327 posted you should be able to sort out your wires.
91Z-28 is offline   Reply With Quote
Old 03-03-2007, 11:49 PM   #5
Marc 85Z28 is offline   Reply With Quote
Old 03-05-2007, 08:53 AM   #6
thx guys i got it done and she is stronger than ever so thx for the help.
Reply
Thread Thread Starter Forum Replies Last Post
Project Frankenbird - spring 2015 - D1SC 383 Lt4, advice welcome! LONG dbusch22 Forced Induction 6 10-31-2016 11:09 AM
1996 Chevy Camaro Z28 SS w less than 19k org. miles F'n1996Z28SS Cars For Sale 6 04-02-2015 10:02 PM
1994 z28 built cheap project Noenav Cars For Sale 1 12-22-2014 09:56 AM
Urgent! No Injector pulse! '94 z28 nophix Fuel and Ignition 3 11-30-2014 10:26 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
