91 z28 305 tpi big probs help !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!
Old 10-31-2012, 09:24 PM
matts91z28's Avatar
Angry 91 z28 305 tpi big probs help !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!
I have '91 Z28 Camaro. 305 TPI, fuel injection. I bought this car a week ago. Here's my problem, it will not cold start on it's on you have to pat the gas pedal, it idles from 1500-1900, if you go full throttle and let off the car will start to shutter and shake then the motor shuts off. I have replaced the throttle position sensor. ok now the car will not idle at all can keep car running if i hold the gas help
matts91z28 is offline
Old 11-06-2012, 09:21 AM
antoine's Avatar
Re: 91 z28 305 tpi big probs help !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I would ohm test the fuel injectors& check how much fuel pressure you have
antoine is offline
Old 01-13-2013, 08:22 AM
purplehaze92z28's Avatar
It could be a bad IAC as well. Have you checked or replaced it?
purplehaze92z28 is offline
F'n1996Z28SS
08-23-2023 11:19 PM
hotrod 5210
12-22-2014 07:28 AM
bossco
11-29-2014 10:18 AM
Carguy00
08-06-2002 10:25 PM
Quick Reply: 91 z28 305 tpi big probs help !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!
