91 camaro rs keeps shutting down
Old 04-24-2011, 05:34 PM
91BlackPearl's Avatar
i got the car with a eldelbrock performer intake and a 600 cfm with a electric choke carb i try a new fuel pump because it seems that there is too much fuel going to the carb,...can i get a lil tip or suggestions ?
91BlackPearl is offline
Old 04-25-2011, 01:44 PM
calaban's Avatar
Re: 91 camaro rs keeps shutting down
What kind of engine is it? What kind of fuel pump are you running now?
calaban is offline
Old 04-28-2011, 08:26 PM
is a 305 i put back the stock pump because i tried a new pump and it didnt work
Old 04-29-2011, 09:01 AM
Marc 85Z28's Avatar
Are you saying that you have an intank electric fuel pump with a carburetor? Hopefully you have a fuel pressure regulator on that system, set to no more than 8-9psi. If you don't have a pressure regulator, well, thats your problem.
Marc 85Z28 is offline
Old 04-30-2011, 05:24 PM
yeah i have a pressure regulator is set at 5 1/2 rite now
Old 05-01-2011, 12:52 PM
Marc 85Z28's Avatar
You're going to have to provide a lot more information than what you're giving us.
Old 05-04-2011, 09:22 PM
Unhappy Re: 91 camaro rs keeps shutting down
sorry about taking long to answer but this the thing I put a new fuel pump the stock that is 12 to 17 psi they guy I got it had it with a kill switch and a fuel pressure regulator set at 5 psi but the car kept choking when I turn it on like if the regulator wasnt doing it's job and letting all the fuel go to the carb...just put a lower psi pump and now the caf drives but when I'm at a light on idle it turns off lights are on so no electrical problem...
HCz28
01-11-2015 11:21 AM
97z28k&N
01-09-2015 04:58 AM
FIREBIRDMARK1
01-07-2015 03:36 PM
Injuneer
12-15-2014 09:36 AM
fpete1992
12-11-2014 03:51 PM
Quick Reply: 91 camaro rs keeps shutting down
