Welcome to CamaroZ28.Com, the ultimate Source for Camaro enthusiasts! Here you can join over 90,000 Camaro enthusiasts from around the world discussing all things related to Camaros and more. You are currently viewing as a guest which gives you limited access to view discussions
To gain full access to our forums you must register for a free account. As a registered member you will be able to:
Participate in over 40 different forums and search/browse from over 5 million posts.
This summer has totally sucked for all of my cars. Nothing but problems. My 89 Formula 350 with 72,500 miles started acting really strange again today. The car started to stumble alot around 1000 rpm and would even die out. After a while my service engine soon light came on so I took it home and scanned it and got a code 34. I know this is mass air flor sensor circuit but what should I be checking for. About 11 years ago I had to buy one for my iroc-z and it was around $240. I called advance auto parts and they said the part is no longer available. Is there a relay for this circuit? If so where is it located?
This ad is not displayed to registered members. Register your free account today and become a member on CamaroZ28.com!
I did pull it out of the car and it was a bosch ( made in germany ). I looked at both screens and they were clean and the wire inside was not broken. It was still connected at all 4 points.
After waiting for 10 days I finally got my new MAF sensor from Autozone. All other part stores were about a 3 week wait. I put it in and all of the problems went away with no check engine light. It was a reman. but came with a 1 year warranty for $150. Autozone was the cheapest around.
