Welcome to Camaro Z28!
Welcome to CamaroZ28.Com, the ultimate Source for Camaro enthusiasts! Here you can join over 90,000 Camaro enthusiasts from around the world discussing all things related to Camaros and more. You are currently viewing as a guest which gives you limited access to view discussions
To gain full access to our forums you must register for a free account. As a registered member you will be able to:
  • Participate in over 40 different forums and search/browse from over 5 million posts.
  • Upload your Camaro details to your Garage
  • Post photos, respond to polls and access other special features
  • Gain access to our free marketplace to buy, sell and trade Camaros, parts and more.
All this and much more is available to you absolutely free when you register for an account, so join our community today today!
If you have any problems with the registration process or your account login, please contact support.
Go Back   CamaroZ28.Com Message Board > 1967-2002 Powertrain Discussion > 3rd Gen / L98 Engine Tech
Sign in using an external account
Register Forgot Password?
Register Garage Photos Blogs FAQ Members List Social Groups Links Calendar Search Today's Posts Mark Forums Read Z28LiveVendor Directory TSBs
Reply Post New Thread
LinkBack Thread Tools Search this Thread Display Modes
Old 04-05-2010, 07:35 PM   #1
88 Z28 bearings out on the crank
I just bought a 88 z28 camaro and it has the tpi. it is bored 30 over and not sure why it blew up. but all the bearings went out on the bottom end. it was recently rebuilt and had less than 10 miles on the run. not sure what went wrong. looking for thoughts. not sure what it has for a cam if its original or not. thinking not. i need some thoughts.
This ad is not displayed to registered members.
Register your free account today and become a member on CamaroZ28.com!
benton_11 is offline   Reply With Quote
Old 04-06-2010, 07:06 AM   #2
Serveral possible answers as to why it blew:
1: Bearings installed incorrectly
2: Bearings installed DRY with no assembly lube
3: faulty oiling system (bad pump, blocked oil passages ect....this could go along with #1, Bearings installed backwards ect could block the oil passages that feed the bearings.)
4: Bearing tolerances could have been too tight or too loose.
__________________
And the good Lord said unto John "Come forth and ye shall receive eternal life." However, John came fifth and all he received was a goat.
R_ADKINS80 is offline   Reply With Quote
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
Garage Plus vBulletin Plugins by Drive Thru Online, Inc.
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
