best L98 nitrous cam
Old 04-04-2010, 10:44 PM
tgates's Avatar
I need to get a cam for my 91 camaro 5.7, i have mild bolt ons and a full exhaust, im putting a 100 shot in it, i need to get a cam that would go good with the nitrous and great without it. im keeping stock heads and tpi system
it will only be sprayed only a few times a season.
my mods-
headers / mid pipe
Exhaust cut out
True ram air system
Throttle body air foil
Adjustable fuel pressure regulator
Ported intake
Complete MSD ignition system,
cap, rotor, coil, 8.5mm wires, plugs,
Jet stage 2 performance chip
Underdrive pulley system (BBK)
27Lb injectors
tgates is offline
Old 04-06-2010, 03:37 AM
onefastgta's Avatar
For a 100 shot you won't know the difference in a nitrous cam. Cam it like you would for N/A and don't worry about the bottle. Stick with a cam within the stock powerband if you are using stock heads and intake.
onefastgta is offline
Old 04-06-2010, 06:59 PM
AutoRoc's Avatar
Maybe try an LT4 cam and 1.6 rockers? Might need better valvesprings, not sure..
Not the LT4 Hotcam, just the LT4 cam..
Every engine should have a 100 shot. The world would be all smiles... haha
AutoRoc is offline
camaroguy50613
05-27-2016 09:00 AM
RUENUF
05-25-2016 08:10 PM
RUENUF
03-13-2016 03:39 PM
MadMav
05-25-2015 09:35 PM
bandit383lt4
12-21-2014 09:12 PM
Quick Reply: best L98 nitrous cam
