87 tpi Distributor help
Old 10-26-2009, 07:42 PM
818camaro95's Avatar
My friend with a 87 305 tpi was doing some maintenance on his car. He decided to replace the module in the distributor and broke the piece that attaches to the module. Does he have to buy another distributor or can he buy a replacement piece?
818camaro95 is offline
Old 10-27-2009, 12:52 PM
crazypurgatory's Avatar
Question
What broke?
Did he just strip the little bolt out?
crazypurgatory is offline
Old 10-27-2009, 07:06 PM
quickchicken's Avatar
there are 3 plugs that plug into the igmod. one is inside the diz and the other 2 are at the back of the diz.
the only things i think he coulda broke are the holding tangs that hold the plugs onto the diz. if thats the case the he should be ok as there is enough clamping force to keep the plug in place.
thats what im getting from this at the moment.
quickchicken is offline
Old 10-27-2009, 10:14 PM
tom2's Avatar
Real common if so. Mine has been broke off for years. I just check it now and then. The small one inside is for the pickup coil, have to pull dist. to replace that part.
tom2 is offline
Old 10-29-2009, 05:02 PM
BigBadLou's Avatar
No, he doesn't. He can just buy the ignition module separately (there's one on sale here in the part classifieds) and install it into the distributor. He shouldn't have to pay more than $30 for the module.
Hope this helps.
Lou
BigBadLou is offline
G-BODYT56
01-14-2022 11:14 PM
68camaroboltz
10-05-2015 01:46 PM
autoxr166
09-25-2015 04:21 PM
Matt Dreessen
09-09-2015 09:58 PM
gonzo275rltw
07-11-2015 04:19 AM
Quick Reply: 87 tpi Distributor help
