88 Iroc dies at stop
Old 05-25-2010, 11:19 AM
ungladiador68's Avatar
I have 1988 camaro iroc .When i first turn it on it drives good for about an hour or so then it starts to turn of at every stop. I have noticed that it is also starting to backfire a bit , it does however turn back on but it will turn off at every stop, very frustrating.I have changed the plugs, the fuel regulator,and fuel filter.I was wondering if anyone here has had this problem or something similar.Could it be a timing issue?
ungladiador68 is offline
Old 05-25-2010, 04:12 PM
gtadude's Avatar
check ur fuel injectors to make sure they are good.how many miles are on the engine?
gtadude is offline
Old 05-25-2010, 06:06 PM
the odomiter reads 75,000 but i was told that the car had a new newer engine with 24,000 miles on it when i bought it. when it does run good it runs great. and I already tried an bottle of injector cleaner...Man i dont know anything about checking the injectors, do you have any info on that.Any help would be appreciated
Old 06-03-2010, 09:20 PM
chrisblanton's Avatar
you can put noid lights on the injectors to check injector pulse you can get them on a tool truck or i've seen them at the advence auto near my house
chrisblanton is offline
Old 06-04-2010, 01:07 PM
gtadude's Avatar
sorry it took so long, theres also whats called a balance test they do on the tpi engines. you should be able too check them with a volt meter too see what voltage there at all injectors have a voltage range for good an bad. i would check all vaccum hose also, oh check the brake booster valve too.
gtadude is offline
Old 06-09-2010, 12:47 AM
stanghunter211's Avatar
Also might want to reset the IAC for minimum air (idle) as well as resetting the TPS to the correct voltage. These two things often go overlooked and can mean the difference between an engine that stays running and one that does not. If you visit thirdgen.org, there is a step by step on how to do this in the tech articles section
Will
stanghunter211 is offline
andrewcapps82
05-19-2015 10:11 PM
reww86
04-27-2015 05:17 PM
Biggiebound
04-20-2015 07:16 AM
BigWil
03-29-2015 12:24 PM
Quick Reply: 88 Iroc dies at stop
