305 TPI Rough running questions - CamaroZ28.Com Message Board
Reply
LinkBack Thread Tools Search this Thread
Old 06-06-2011, 02:23 PM   #1
I took the car out of winter storage and drove it around for a bit, perfect idle and lots of power. After sitting for a few hours the car was idling rough and the tach showed no rpm's the engine had reduced power and I can smell raw fuel. After a few minutes of driving the tach started working but still rough idle and reduced power. I pulled the spark plugs and all looked fine, I replaced them anyways. While it was idling I wiggled the wires and nothing changed.
What and how do I check wires and distrubutor for problems. I'm pretty sure it's not a computer problem but I can't rule it out.
Nick's WS6 is offline   Reply With Quote
Old 06-06-2011, 11:41 PM   #2
Re: 305 TPI Rough running questions
First of all more info would be great. What kind of car. Camaro/Firebird or another car that a 305 TPI has been transplanted into it. I'm thinking a firebird based on your user name.
cars3 is offline   Reply With Quote
Old 06-07-2011, 01:27 AM   #3
Firebird is sold. It's in the porsche. 1986 305 not sure about what kind of car it was originally intended for.
Old 06-07-2011, 02:30 AM   #4
Bad gas from sitting over winter.
Gtpguy is offline   Reply With Quote
Old 06-11-2011, 11:30 AM   #5
Could be bad gas but I used stabil.
I replaced all the spark plugs and wires with no change. It does sound like it's only 1 cylinder not firing though. The left exhaust sounds fine but the right one sounds rough and smells like raw fuel.
It has a full tank, how much damage am I risking by driving the car til it's empty then filling up again so there is fresh gas in it?
Old 06-11-2011, 01:57 PM   #6
I bought a firebird with a tank of bad gas and I was told by the mechanic to just drive it out. The night I bought it, it ran so weak I popped the hood and one of the manifolds was glowing orange. Sure enough it was just a bad tank of gas.
The gas might be so bad that stabil doesn't even affect it. I'd stay around your neighborhood and drive it there or let it idle in your driveway until its gone. Or syphon it out?
Get that gas out of the tank to eliminate that if its something else.
Old 06-12-2011, 12:28 AM   #7
So I ran a half tank out of the car driving all day, it's just too damn good on the mpg. Once it got up to temp on every shift there was a backfire out the right muffler. I really don't think it's bad gas.
Old 06-12-2011, 03:39 AM   #8
You said its an 86. Does unhooking the maf change the way it drives? Do you have access to a scanner?
What I would do is run the tank dry and fill it up. See if it improves. Then I'd do a full tune up. Wires, coil, distributor cap, MAF relays go bad and are cheap to replace.
Report back when you get a new tank of gas in there.
Old 06-12-2011, 12:02 PM   #9
I don't think it has a maf. here is a picture of the engine, you can't see the whole intake but it's just a tube. http://i.imgur.com/L2V0l.jpg
Old 06-12-2011, 08:00 PM   #10
You can see the Map sensor on the side of the plenum. In Fbodies that would be on the passengerside. I can't tell how the motor is positioned in the porsche. That means its not from an 1986, but from a 1990-1992. MAF cars were 1985-1989. That doesn't point to anything, but if someone gave you a 1986 computer wiring harness with a Speed density motor, that will be a big part of your problem.
I assume the check engine light on your dash works in conjunction with your computer? If not, you need to see what codes are possibly popping up.
Old 06-12-2011, 08:08 PM   #11
If you are talking about the probe sticking out, thats the driver side. The engine is facing the same way it normally would be in a Fbod but it's in the back of the car. Your right shoulder would be where the bend in the intake is. The car has been running fine for years, just now has it started to act funny
Old 06-12-2011, 08:15 PM   #12
Are there any codes that pop up?
No the little black box on the passenger side right behind the back runner tube. That is the MAP sensor. The probe on the driver side is merely there to hold a tie down bracket for the the throttle and TV cable to stay in place. Looks like you had bracket made.
Old 06-12-2011, 11:18 PM   #13
That's not a 1986 motor because of the map sensor as stated above. Unless someone took an 86 motor and a 90-92 plenum and put them together.
Old 06-13-2011, 12:46 AM   #14
I was told it was an 86 motor but it could be just about anything because it was never actually in a car. Lets just say it was supposed to be destroyed but never made it to the dumpster.
Old 06-13-2011, 11:45 PM   #15
Quote:
Not sure what you mean by was supposed to be destroyed, but who cares, another TPI motor still in service. Put's a smile on my face no matter what car it's in. Sorry no further help at this time.
Reply
Thread Thread Starter Forum Replies Last Post
LT1 Perf Parts: Ported heads, rockers, BBK TB etc... oldschool Parts For Sale 16 02-09-2016 10:21 PM
pops and cracks hotrod 5210 Fuel and Ignition 4 12-22-2014 08:28 AM
1992 b4c 1le police interceptor for sale Lederman1976 Cars For Sale 0 11-30-2014 06:21 AM
Separate "For Sale" please!!! Carguy00 Site Help and Suggestions 1 08-06-2002 11:25 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
