1990 iroc-z 305 v8 help
Old 09-02-2014, 07:28 AM
Phoenix AZ's Avatar
Hi!
I have a 1990 iroc-z 305 v8...I change a complete distributor ...I have a question it is possible that the engine starts even if the firing oder is not right and can it cause over heating and running rough? thank you
Phoenix AZ is offline
Old 10-15-2014, 08:29 AM
ws6transam's Avatar
Re: 1990 iroc-z 305 v8 help
Yes, it'll start. Check to see if you haven't swapped two cylinders by mistake. If you get # 2 & 4 swapped, it'll run just like you are saying. Also, if you have the timing really advanced, or really retarded, it will do that. Lastly, if the distributor is not plugged into the harness properly, it will not have any electronic advance, and it will run and overheat like that. Re-check those things, go over every single plug wire, from the spark plug to the terminal on the distributor to make sure it's plugged in on the correct post.
ws6transam is offline
Old 10-15-2014, 12:09 PM
Phoenix AZ's Avatar
Thank you ws6transam after al the check go the ca running great everything back to normal....distributorwas not plugged into the harness properly....Have a great weekend
Old 10-16-2014, 01:14 PM
ws6transam's Avatar
that's great to hear!
Enjoy your car
Tarizza
09-20-2015 03:26 PM
gonzo275rltw
09-07-2015 04:46 PM
gonzo275rltw
09-05-2015 06:26 PM
gonzo275rltw
09-05-2015 06:24 PM
Rittmeister
08-07-2015 01:13 AM
Quick Reply: 1990 iroc-z 305 v8 help
