1987 Iroc Stalling
Old 08-01-2010, 11:04 PM
ungladiador68's Avatar
1987 Iroc Stalling
Hello, dont know if this is an egnition or fuel issue. 1987 Camaro iroc 5.7 ltr. Car turns on fine, sometimes there is a little hesitation but it always starts.The problem is that it seems like is running rough stalling on first and second gear like it wants to turn off ,actually it was also turning of when coming to a stop but it has not done that in a while...Its ok once i go into third and fourth gear also 5th runs gerat... We have replaced the plugs and wires.fuel filter.ignition module to try to fix this.. If anyone has come across this issue or some can gear me in the right direction , i would greatly appreciate it..thanks
ungladiador68 is offline
Old 08-02-2010, 05:06 AM
Have you scanned the ECM for codes? Have you checked the fuel pressure?
Injuneer is offline
Old 08-02-2010, 09:22 AM
Thanks for the reply.Im not a mechanic . Me and my brother have been doing all the work on trying to restore the car so please bare with me..There is no check engine light on....I was told that if there is no "check engine light" on that the scanner will show no trouble codes,,Is this correct.? is this the codes tha you talking bout..also how would i be able to check for fuel pressure?
Old 08-02-2010, 09:59 AM
Z28SORR's Avatar
http://www.autozone.com/autozone/acc...mString=search
Z28SORR is offline
Nayr
03-03-2023 08:34 PM
Matt Dreessen
09-09-2015 09:58 PM
gonzo275rltw
09-07-2015 04:46 PM
gonzo275rltw
09-05-2015 06:26 PM
gonzo275rltw
09-05-2015 06:24 PM
Quick Reply: 1987 Iroc Stalling
