1.6 Roller tip rockers, Will they fit???
I have a 305 that I want to put Comp cams magnum 1.6 roller tip rockers on but I don`t know if they`ll make the retainers hit the head. The heads are just normal 305 heads with some intake work done to them. the cam is a Crane 272 H10 with .454" lift.
they are Crane single coil springs there WAY stiffer than the stock springs, I bought them with the cam because they recomened them because the stock springs were way to weak to handle the lift and they had 285000 km on them
Speeds8erM-1
07-18-2002 11:36 PM
