Will 275 OE REARS FIT ON THE FRONTS?
I have been asked this question maybe 20 times. Working on the WD40 car, I had some time to be able to check some of the oddities such as this. We had the front cambers set at -1.0 degrees camber and the rear SS wheels and tires fit on the fronts. There was approximately a pencil width clearance between the strut and the tire. But that is OK. The cambers I set the front end is moderately aggressive, and is the max I would put it at for clearance issues.
Mike
dms
Mike
dms
Omega9
08-17-2002 04:23 PM
