2010 - 2015 Camaro Wheels, Tires, Brakes, Suspension Discussion for 2010 - 2011 - 2012 - 2013 - 2014 - 2015 Chevrolet Camaro Wheels | Tires | Brakes | Suspension
[Brakes] Squealing brakes
Old 07-28-2010, 10:33 PM
Bittle's Avatar
Squealing brakes
Still have the same anoying squealing brakes on my 2SS RS. Now the dealer is going to change the brake pads. Will see if this in fact works. I am not at all pleased with the solution thus far. The dealer ship is trying to correct the problem so hats off to them.
Bittle is offline
Old 07-30-2010, 05:27 PM
Admin Emeritus
JasonD's Avatar
Are these front or rear or both?
JasonD is offline
Old 08-02-2010, 08:37 AM
2010_5thgen's Avatar
go with something like hawk pads.
2010_5thgen is offline
Old 08-04-2010, 10:47 PM
Justice Pete's Avatar
Brembo high performance brakes tend to do this. You'll find owners of high priced prestigious makes with the same complaint. We have had some good success with clients using the following bedding procedure.
Without coming to a full stop...
reach a cruising speed of 40 miles an hour and stand on the brakes HARD down to 20
reach a cruising speed of 50 miles an hour and stand on the brakes HARD down to 20
reach a cruising speed of 60 miles an hour and stand on the brakes HARD down to 20
drive a couple more miles to let the brakes cool before coming to a complete stop. An empty stretch of highway late at nigh or early in the morning will work as you are not speeding, but you are driving erratically so be careful. This won't take long and for most people it works well. Give it a try and let up know the results.
Justice Pete is offline
Old 08-05-2010, 08:03 PM
Admin Emeritus
JasonD's Avatar
Pete, you are referring to the factory Brembo brakes and factory pads, right?
JasonD is offline
Old 08-05-2010, 09:46 PM
Correctamundo. The way I treat my Cobalt Friction pads would probably melt the OE pads.
magman
04-15-2016 03:08 AM
IndyZman
10-22-2015 02:17 PM
Matt Dreessen
09-09-2015 09:58 PM
maverickmk
09-01-2015 09:17 PM
colts0455
07-07-2015 07:19 PM
Quick Reply: [Brakes] Squealing brakes
