2010 - 2015 Camaro Wheels, Tires, Brakes, Suspension Discussion for 2010 - 2011 - 2012 - 2013 - 2014 - 2015 Chevrolet Camaro Wheels | Tires | Brakes | Suspension
[Tires] question about Tire Pressure Monitoring System
Old 08-13-2009, 07:28 PM
hollywoodjose's Avatar
hey everyone I was just wondering if you check it very often while driving, and what your normal readouts were. I was just curious because today my back right tire seemed kinda high, normally my front left and back right match and my front right and back left match. I'm gonna read my book to see what it normally is. Any input would be appreciated
hollywoodjose is offline
Old 08-13-2009, 07:48 PM
Admin Emeritus
JasonD's Avatar
Supposed to be 36psi. Temperature makes a difference, and makes the numbers fluctuate at little bit.
JasonD is offline
Old 08-13-2009, 07:51 PM
thank you for writing, all of them should be 36? cause today the front two were 36/37 and the back ones were 38/39, sometimes i've seen it go as high as 40 i believe.
Old 08-13-2009, 08:05 PM
Admin Emeritus
JasonD's Avatar
Right, they change. Temperature makes a difference. Driving makes the air temperature rise sometimes. I just checked the owners manual...
Check the tire’s inflation pressure when the tires are cold. Cold means
your vehicle has been sitting for at least three hours or driven no more than 1 mile (1.6 km).
So check them tomorrow morning and let us know what they say then!
JasonD is offline
Old 08-14-2009, 07:11 AM
2010_5thgen's Avatar
i noticed mine fluctuate quite a bit also. mine are set at 36all the way around and get up to 40 when driving
2010_5thgen is offline
Old 08-16-2009, 03:35 AM
i went in this morning and had them all checked and they were at like 30, the guy put 35 in (on the inside of the door it said 35 on mine) and all but the back right tire stayed close to the same, but the back right was like 3-4 psi higher
also this is embarassing but today i was tryin to find a parking space in this cramped *** parking garage and caught a curb a little bit. I kept checking the pressure on that tire with the TPMS and it seemed okay but when i had some rims a friend gave me they had ading from hittin a curb and it didnt seal properly so the tire would not hold air, and my question is if it didnt lose anything according to the TPMS do you think it should still be okay? i could post pics if that would help
Old 08-16-2009, 06:13 AM
Admin Emeritus
JasonD's Avatar
Hard to tell, post some pics.
JasonD is offline
Old 08-17-2009, 06:54 AM
if its not losing air, thats a good thing. but beingthat you curbed the wheel, thats a bad thing.
F'n1996Z28SS
08-23-2023 11:19 PM
DirtyDaveW
12-01-2016 05:37 PM
Hurin
12-13-2014 07:38 PM
07-04-2005 05:00 PM
Quick Reply: [Tires] question about Tire Pressure Monitoring System
