[Suspension] Pedders takng orders for drop coils with options!
Pete did a mutliple test fit of our Pedders coils only on a 6 cylinder Camaro with 20 inch wheels. the OE heights were at:
Front 690mm
Rear 700mm
We installed our front coils to a final height of 667mm. Rears are different. We know the extra weight of the Camaro and the shorter wheel base. Spring rates on these coils will be proprietary but will be in the 30-50% higher than OE rates. We know there will be a large amount of Camaros that owners will want to install larger, oversized wheels that may not have the most efficient offsets. and oversized rear wheels will add to the Camaro's aggressive understeer. These Camaro owners may elect to go with a drop that will lower the vehicles slightly to allow a larger wheel and tire. For those customers then our first level rear coil will be perfect for you. The first level rear coils will drop the rear to 675mm from 700mm OE height.
Then we will have the Camaro owners that want the looks and want to max out on handling with the our upgraded coils. This is accomplished by our second set of rear coils, that will drop the back end to 660mm. this is a 15mm drop lower than our first set of rear coils and is a engineered, specific goal. The 15mm drop will really help on the aggressive understeer that seriously plagues the Camaro and will add to the aggressive stance of the Camaro as well. Wheel fitment may become more of an important influence over the first set of coils
Pictures are coming.
Now here are the assigned part numbers for our new Camaros:
220032 Ride Height with 20" Wheels 667mm
220035 Ride Height with 20" Wheels 675mm
220033 Ride height with 20" Wheels 660mm
We now have 2 coil drop kits for your selection. The pricing is preliminary, and orders were placed last week. Here are the 2 coil only drop kits:
Camaro Drop Spring Kit 1 By Pedders
Merlin Store P/N is ______________________
This kit is for the enthusiast that is looking for that aggressive look over performance and may need a slightly higher rear stance due to oversized wheels and tires. This kit offers a 20-25mm drop in ride height. With higher coil ratinings and a lower vehicle stance, performance iimprovements is a real plus
ç
Part # Pedders Compnent Price
220032 "Camaro 2009 Front drop Coils & Ride Height with 20"" Wheels at 667mm
" $89.62
" $89.62
220035 Camaro Zeta Rear Coil Ride Height with 20" Wheels 675mm $89.62
Pedders Drop Coils Only Parts Total $358.48
Menu System Discount $38.49
Menu System Discount Adjusted Parts Total $319.99
Camaro Performance Drop Spring Kit 2
This kit is for the enthusiast that is looking for that aggressive look with with a more performance oriented handling experience. The fronts are a 20mm drop and the rears are a 40mm drop. This look is a European look, and will seriously reduce the significant amount of understeer the new Camaro offers.
" $89.62
" $89.62
220033 Camaro 2009 Rear Drop Coils & Ride Height with 20" Wheels at 660mm $89.62
Coil orders were placed last week. You can be the first to get yours by contacting us and getting the orders advance. Our Merlin store is not yet set up for these kits. So contact any of your Pedders dealers that are sponsors here on this great forum and we can assist you. If we have a price difference, you will get the lower price. If the price is not at this level, then you will get this price until it is posted about the change.
It has not been confirmed an ETA for these coils. This information will be given out the moment we have a date.
thanks to all for you patience.
If you need assistance or have any questions, just ask
thanks
mike
dms
Front 690mm
Rear 700mm
ç
" $89.62
" $89.62
" $89.62
" $89.62
thanks
mike
dms
Pedders Camaro Performance Drop Coil Pictures!
Here are some pictures of our stock 6 cylinder Camaro with 20 inch wheels and tires running our drop coils only:
Lowered red V6 Camaro
220032 Front 667mm with 20" Wheels
220033 rear 660mm with 20" Wheels
Hope this helps. Sorry for taking so long to get them!
If you have any questions, just ask
thanks
mike
dms
thanks
mike
dms
10-31-2016 11:09 AM
Sergio
01-27-2016 04:27 PM
01-23-2015 01:13 PM
