[Suspension] Pedders 1 Inch Drop Coils Installed!! Looks & handles Awesome
Pedders has been late in the game with our drop coils. But we are now in the game to win. Our 1 inch drop coils offer serious comfort, improved handling, and a great look. We designed these coils so you do not have to cut the bump stop, which is a big deal to protect the OE dampers. The 1 inch Pedders drop coils installed are:
220032 front drop coils
220033 rear drop coils
EO Camaro SS with 20 inch wheels
Pedders Drop Coils Installed
Coils are not made the same Here are 2 different 1 inch drop coils manufactured by different companies. . Look at the difference:
Other manufacture of 1 inch drop coils
Pedders 1 inch Drop Coils
Look at the 2 sets closely. You will see the Pedders coils use more coil wraps and larger coils. This makes a higher quality ride, and longer life, and better performing coilsPedders 1 inch Drop Coils
Here is an old school look. 1 inch drop coils and OE height rear
The above look can be obtained using the following Pedders Performance coils:
2200322 front 1 inch drop coils
220035 rear approximately 13mm (1/2) inch rear for SS drop springs
Installing these matched coils will offer you great performance enhancement and balance. It will also give you a old school look and may allow you to fit a larger tire and wheel in the rear that may not fit properly.
If you have question, just ask
mike
dms
We talked about this in CamaroZ28.Com Podcast #245. Have a listen here!
F'n1996Z28SS
08-23-2023 11:19 PM
10-31-2016 11:09 AM
Carogna'sZ-28
02-03-2015 07:04 PM
