2010 - 2015 Camaro Wheels, Tires, Brakes, Suspension Discussion for 2010 - 2011 - 2012 - 2013 - 2014 - 2015 Chevrolet Camaro Wheels | Tires | Brakes | Suspension
New Tire on Same Wheel Loses Pressure.
Old 09-26-2011, 10:52 AM
Kurt Crosbie's Avatar
Just purchased two new tires recently after my LR kept going flat. I am now experiencing that same problem on the same wheel with a new tire. The wheel itself looks like its in fine shape. I don't see any curb rash on it or bends. What are the chances I purchased another tire with a leak in it? What should I be looking for?
Kurt Crosbie is offline
Old 09-26-2011, 11:02 AM
Admin Emeritus
JasonD's Avatar
Re: New Tire on Same Wheel Loses Pressure.
Odds are slim the tire is bad. Odds are good the wheel is bad.
Just the slightest variance in the wheel can make it leak, including corrosion around the bead area, it being slightly out of round, etc.
How fast does it lose air?
JasonD is offline
Old 09-26-2011, 12:34 PM
Takes 2-3 days. Guess I will buy a new wheel.
Sent from my SCH-I800 using Tapatalk
Old 09-26-2011, 12:57 PM
Admin Emeritus
JasonD's Avatar
Stock wheel? Take it back to the dealership, it should still be under warranty unless you put a lot of miles on it since 2010.
JasonD is offline
Old 09-27-2011, 02:20 PM
I don't know if it was corrosion, but it looks like the chrome had built up in some areas where it meets the tire. Never seen anything like that before. Is it common?
Sent from my VS910 4G using Tapatalk
Old 09-27-2011, 02:48 PM
SSCamaro99_3's Avatar
Tire Pressure sensor could be an issue. My brother had this on his Jeep. Brand new tires losing air.
SSCamaro99_3 is offline
Old 09-27-2011, 03:22 PM
I don't think 95's had tire pressure sensors.
Old 09-27-2011, 03:28 PM
Admin Emeritus
JasonD's Avatar
In that case, I don't think you meant to post your thread in the 2010 - 2011 - 2012 Camaro Wheels, Tires, Brakes, Suspension forum.
JasonD is offline
Old 09-27-2011, 04:12 PM
Oops
F'n1996Z28SS
08-23-2023 11:19 PM
Moshbmx1
01-20-2015 03:27 PM
Jason Short
01-19-2015 06:33 PM
Doug Harden
29
07-30-2003 07:05 AM
Quick Reply: New Tire on Same Wheel Loses Pressure.
