[Suspension] Camaro drag suspension kit installed
Camaro Set up with Drag Package
I had the pleasure today certifying yet another California dealer, an new Chevrolet dealer! John L Sullivan, in Roseville, Ca. is now officially Pedders Camaro Certified. They have our Camaro coil overs and our Camaro drop coils in stock! Bill is service advisor I dealt with, a great guy and very customer oriented. The tech is awesome. His name is Mike and is the only tech that will do Pedders.
The kit we put in is our Pedders Drag Xa Kit, a very serious kit. Here it is:
Item Code Description Qty
160086.......................Camaro Ext Xa Adjust Coilover 1
EP1167HD.................. Zeta HD Differential Mounts 1
EP1201HD..................Camaro HD Rear Sub Frame Repl 1
EP2112 ......................Zeta Steering Rack/Pinion Mnt 1
EP6577.......................Camaro Front Radius Rod Bush 1
EP7264.......................Zeta Rear Lower Control Arm In 1
EP7322 ......................Camaro Rear Upper Control Arm 1
EP7323 ......................Zeta Rear Trailing ArmToe Link 4
PDUSACAMFULL ..........Camaro Full Alignment Kit 1
Here are some pictures:
BEFORE INSTALL. THIS CAMARO WAS EXCEPTIONALLY HIGHER THAN THE NORMAL SSII
AFTER PICTURES SET UP FOR 75% AGGRESSIVE STREET, AND 25% AGGRESSIVE DRAG
HERE ARE THE PICTURES OF THE MAJOR COMPONENTS FOR THE DRAG XA
FRONT RADIUS ROD HD BUSHINGS THE OEs ARE FLUID FILLED AND OFFER SOME CONCERNS FOR MAXIMUM PERFORMANCE
FRONT RADIUS ROD INSTALLED
FRONT CASTER ECCENTRIC INSTALLED. INCREASED OE CASTER BY 2.35 DEGREES
POWER STEERING RACK POLY BUSHING INSTALLED
PEDDERS EP1167HD REAR DIFF VERY HEAVY DUTY BUSHINGS INSTALLED IN THE CAR WITHOUT REMOVING THE DIFFERENTIAL
REAR UPPER CONTROL ARM BUSHING. CRITICAL FOR WHEEL HOP REDUCTION
Camaro drag suspension kit installed part ii
THE REAR PEDDERS EP1201HD SERIOUSLY HD SUBFRAME BUSHING
FRONT PEDDERS EP1201HD SERIOUSLY HD SUBFRAME BUSHING
TRAILING ARM PEDDERS BUSHING IN KNUCKLE ASSEMBLY
TRAILING ARM LINK AND TOE LINK PEDDERS BUSHINGS INSTALLED
PEDDERS REAR LOWER CONTROL ARM BUSHING INSTALLED
REAR XA COIL OVERS AND REAR CAMBER ECCENTRICS INSTALLED. WE WERE ABLE TOT GET TO POSITIVE CAMBER WITH THIS CAMARO WITH A 1.5 INCH DROP!
FRONT XA COIL OVERS INSTALLED
The alignment was modified to assist the aggressive drag request. Vehicles was lowered front and rear but at strategic level.
Hope you enjoy it.!
thanks
mike
dms
Hope you enjoy it.!
thanks
mike
dms
CARiD
12-26-2014 04:20 AM
12-04-2014 11:56 AM
