2010 - 2015 Camaro Wheels, Tires, Brakes, Suspension Discussion for 2010 - 2011 - 2012 - 2013 - 2014 - 2015 Chevrolet Camaro Wheels | Tires | Brakes | Suspension
Brake Calipers
Old 04-07-2015, 07:44 PM
CGM2010CAMARO's Avatar
Brake Calipers
Hi all,
So I decided to get my brake calipers powder coated and they turned out great. After re-installing everything, I can't seem to get the brakes to work. The front left seems fine, but the right front is almost stuck shut and the rear's will not stop.
I currently have the care on jacks and am testing the rears by putting it in gear and then pressing the brakes. I actually noticed that only one rotor is spinning too. Are both supposed to spin in opposite directions?
Also, with the engine running and the car on jacks in gear, as I depress the brakes, I almost feel like the brake pedal is fighting back.
Is there a special bleeding process when all four calipers are removed at the same time? I have fluid coming out of all 8 bleeders.
I also don't think that the powder coating place covered the holes properly and I fear that there is sand inside the calipers. Any suggestions?
CGM2010CAMARO is offline
magman
04-15-2016 03:08 AM
IndyZman
10-22-2015 02:17 PM
Henson071
09-18-2015 04:01 PM
Matt Dreessen
09-09-2015 09:58 PM
maverickmk
09-01-2015 09:17 PM
Quick Reply: Brake Calipers
