RevXtreme's RPE800 Twin Turbo 2010 Camaro Upgrade
Boost your new Camaro's output nearly double with the explosive performance of a twin-turbo 415cid stroker. The RPE800 is the latest American V8 to harness RevXtreme Performance & Engineering’s legendary track record of building high-horsepower, turbocharged muscle for outstanding performance gains.
Power:
• 810 HP
• 782 lb-ft TQ
RPE800 Upgrade Package Includes:
• 415CID Stroker Engine
• Forged Low Compression Pistons
• Forged Steel Connecting Rods
• Callies 4340 Forged Steel Crank
• Balanced and Blueprinted
• ARP Main Studs & Head Bolts
• Ported Cylinder Heads w/ Valves & Valve Job
• RPE800 Custom Spec Camshaft
• Melling Oil Pump
• RevXtreme 90mm Throttle Body
• Ported Intake Manifold
• Upgraded Fuel Injectors (Plus 8 Secondary Injectors)
• Upgraded Fuel System (Includes Lines, Rails & Secondary Pump)
• Twin Ball Bearing Turbochargers
• Dual Waste-gates
• Boost Controller
• Stainless Steel Turbo Manifolds
• 3 inch Stainless Steel Exhaust
• High-Flow K&N Air Filters
• Professional Installation
• Dyno Tuning & Road Testing
• RPE800 & RevXtreme Badging
• Limited Edition Dash Plaque & Engine Plaque w/ Serial Number
• Optional 1 Year / 12,000 Mile Limited Warranty
REQUIRED TRANSMISSION UPGRADE
• 6spd Manual: Twin Disc Clutch
• Automatic: Performance Build & Torque Converter Upgrade
Additional Appearance and Performance Options
for the RPE800 also Available
• Exterior Graphics Package
• 2 or 3 pc Lightweight Wheels
• Full Coil over Suspension Kit
Carbon Body Kit
Call RevXtreme Performance & Engineering Today at (941) 755-3535 for More Information.
Package components and availability subject to change.
Power:
• 810 HP
• 782 lb-ft TQ
• Melling Oil Pump
• Dual Waste-gates
• Boost Controller
Carbon Body Kit
F'n1996Z28SS
08-23-2023 11:19 PM
