Oil change on an SS: wait until it asks?
#31
Okay, old conversation, but let's resume where we left off.
An oil change shouldn't be a dry start, because you're supposed to do it while the engine is still warm. Unless you take weeks to complete an oil change, the top end and all of the bearings will not be anything remotely close to "dry". There's still plenty of oil up there. Also, one side gets doused pretty heavily with oil when you pour it in. That's not worked into the bearings, but the residual old oil is still there for the ~5 seconds it takes for oil pressure to build once you start the engine.
If you're really a stickler, fill up the new filter with new oil before you put it on. That knocks the ~5 seconds down to ~3. I do it on my Camaro because the filter installs vertically and it's easy. On my Bonneville the filter installs horizontally, so I just put a little bit in.
There is one way and only one way to do an oil change with out doing a dry start up. I do this religiously on all new or rebuilt engine I do. just before I start the engine for the first time, I remove the distributer "on those that have the Old style" drop in a long shaft that is connected to a power drill and run the oil pump for about 10 minutes. then I start it up.
In any case every body make to much out of an oil change. just stick with synthetic oil "a good brand" and keep close watch on the oil pressure and temp. consider the type of driving condition as well. Freeway driving does far less harm then stop and go does. This is where moisture comes in to play. High humid climate areas have more oil issues then dry areas. I use my Camaro mostly for travel, about 90 percent is freeway driving. I have kept very close tabs on the oil and at 13,000 it was still semi clear as if it had only 3000 on it.
A drop in oil pressure over the years is an indecator on just how much wear is on the bearings and the crank shaft. If after 100.000 miles your oil pressure is still at the same pressure then when you first bought it then your doing great. The only time some one needs to worry is when the pressure drops below 5 PSI at an ideal. If so.... you have alot of wear. at this point I would not take the car to the strip and drag race it. You will spin a bearing!!!
Now oil presure on a modified pro stock engine works different. the bearing clearance is greater then stock. The oil pumps on Pro stock and bigger engines have higher volume pumps to acount for the greater bearing clearance, but not always high psi. This creates less drag but lower pressure at an ideal then a stock set up. But then these engine will not last on the street for very long. Street rods go stock. drag engine normally never see the street. Oil Pressure pump system in all engines is the same as any hydraulic system, it is applying a pressurized oil barrier between the bearing and the journal surface trying to floot the crank journals away from the bearings. With out any oil pressure the journal surface is rubbing hard against the bearings.
#32
Re: Oil change on an SS: wait until it asks?
http://www.pre-luber.com/index.htm
http://www.autoenginelube.com/
http://www.prelube.com/
http://www.motorprelube.com/
Any one using any of these products?
#33
I would not let my new car go 13k without an oil change,but changing oil every 3k is a marketing tool used by oil companies to boost profit period.
My 4 gen t/a i changed the oil every 5-7k miles and after over 100,000 the top end looked very clean when i had it apart last yr.
You are free to do what you want .
#35
Every 3k is a bit much imo. This thing takes 8.6 qts of oil for each change! I'd hate to do that more often than is necessary...
What about oil filters? What are you guys running?
#37
I use the K&N oil filter. Has a nice removal nut on the bottom, seems to have favorable reviews and is built like a tank.
Also, consider the Royal Purple oil filter. There used to be a very impressive video out there on YouTube showing how they are made, but I can no longer find it.
#38
AH! Found it. Don't ask me how, as it is unlisted for some dumb reason.
[autostream]http://autostream.com/camaroz28/?page_type=firebirdplayerthumbnail&framepage=1781& transactionid=1316796863-638515170&posted_by=JasonD_www.camaroz28.com&youtu be_video_id=K7UGmAEqwHI[/autostream]
#39
Perhaps they do flow better but I can tell you their filtration is garbage. An opinion I also hold with regard to their air"filters" (and also backed by oil analysis results on more than one of my personal cars over the years).
Oil filtration quality improved dramatically when I tried Mobil1 filters.
The filtration of ACDelco oil filters is also superior to that of the K&N (at least in my experience and my oil analysis results).
#40
Not really surprising. It seems that when it comes to things like this...some think they are great, some disagree.
I was considering trying the Royal Purple filter anyway.
#41
#44
These guys all pitched in and tried to find out themselves.
http://www.svtperformance.com/forums...-needed-5.html
I know they haven't finished yet, but they did find some crappy brands, and they found the Mobil 1 filter to be quite good. I'm still waiting for the article, but I doubt they'll ever get to it at the pace there going.
#45
Don't buy into the 3 months or 3k miles BS. Ever notice who says that the most? The places that ding you for $40 a standard oil change. They make 75% markup on their services (just a guess, but I would be surprised if I wasn't close), so of course they tell you that you need it more than you really do.
