need wheel hop help
Old 03-20-2010, 10:17 AM
powerhog's Avatar
need wheel hop help
I put on a CAI on my 2010 LS3 camaro and found it to be a worth while Mod. I could'nt believe the response, now I have wheel hop with both the traction control and the stabilitrac turned off, whats offered to elimanate wheel hop while getting on it hard from a dead stop?
powerhog is offline
Old 03-21-2010, 10:06 AM
powerhog's Avatar
P.s.
went with BMR trailing arm, also Borla S-type, skip shift, aint this fun!
powerhog is offline
Old 03-21-2010, 02:58 PM
Admin Emeritus
JasonD's Avatar
I thought the trailing arm was supposed with help with wheel hop.
JasonD is offline
Old 03-22-2010, 09:47 AM
2010_5thgen's Avatar
i put BMR trailing arms and toe rods on my car. it helped for sure. i also did the subframe connectors.
2010_5thgen is offline
Old 03-22-2010, 12:51 PM
powerhog's Avatar
sub-frame connectors???
I am not sure what sub-frame connectors and tie rod ends do, I do not road trac race, I want the wheels to stay down on the pavement when I launch, it seems the traction control and stibilitrac rob power so I turn it off. Please explain?
powerhog is offline
Old 03-22-2010, 02:53 PM
subframe connectors just tighten up everything underneath. helps alot in quick cornering and i dont see how it wouldnt help when transfering weight to the rear wheels on a launch.http://www.bmrfabrication.com/F5.htm
force10
08-10-2015 08:30 AM
240ssLs3
07-13-2015 05:06 PM
Slayer
07-04-2015 03:06 PM
SAR2K
09-01-2002 10:49 AM
wytblur
08-05-2002 02:03 PM
Quick Reply: need wheel hop help
