My 2010 L99 died today
My 2010 Camaro just died today I have 5k on the car. I made a left hand turn onto interstate ramp and it just died. Almost everything quit working.
It wont crank over the fuel gauge does not work the radio, onstar, ignition dead.
The display between tack and speedometer says service stability control message. The traction control and stability control display lights show both turned off but when it quit both were turned on.
I had the car in normal drive, and had moderate throttle applied.
We plugged in a computer to the system but can't communicate with onboard computer.
Anyone with similar problem please post
I hope to know more monday.
Checked all fuses ok
Sounds like that problem they were havin when they first hit the streets, where the starter wire was coming in contact with the exhaust or something. Was supposed to be recall notices sent out. Try lookin around there.
DEFINITELY sounds like a short somewhere. Your Battery Cable touching the ground or something to that nature. There's no other way EVERYTHING could stop working like that unless everything stopped receiving juice at once.. ..also be warned that some of your electronics could be fried now...
I don't agree that it's clearly a joke, but I'm not so worked up about it either. I do get annoyed when 3rd gens are bashed. They're gaining in appreciation again now, so I'm sure this "turd gen" thing is on the way out.
ChrisFrez
02-22-2015 08:47 AM
