Horn and Programer
Old 07-17-2011, 02:21 PM
j.pratt7's Avatar
Location: Camp Lejeune, NC (Military) also Manchester, MI
Horn and Programer
Im trying to put in an aftermarket horn on my 2011 V6 but i cant for the life of me find where its at in the car, could anyone tell me where its located at in it.
I am also trying to find a good not to pricey programer any suggestions?
j.pratt7 is offline
Old 07-17-2011, 05:05 PM
Admin Emeritus
JasonD's Avatar
Re: Horn and Programer
Why would you want to change the horn? I believe you need to remove the front clip to get at it.
To do so, jack the front up, remove the front wheels. Remove the screws and fasteners that hold the inner black plastic fenderwell into place. If you look up and deep inside by where the front clip meets the front fender, you will see the nuts that need to be removed. There is also a screw and a nuts by the turn signal that needs to be removed as well. You also need to remove the bolts and fasteners under the hood that hold the front clip on. Once all the fasteners are off, the entire front clip comes straight off...there are pins that guide it out (and in when you reinstall it). There is a harness connector on the passenger side that needs to be disconnected that you cannot see until you start to slide the clip off.
As far as programmers, you would be better off getting a dyno tune, they get more power and are tailor-made to your car. Do you have a speed shop in your area?
JasonD is offline
Old 07-17-2011, 06:45 PM
j.pratt7's Avatar
thanks theres a speed shop just a few miles away.
j.pratt7 is offline
Old 07-17-2011, 07:11 PM
Admin Emeritus
JasonD's Avatar
Make sure they have good references!
JasonD is offline
Old 07-17-2011, 08:25 PM
j.pratt7's Avatar
Thx I will, and I probably won't change the horn, I thought I would be easier. When I get it tuned will it remove the speed and rev limiter?
j.pratt7 is offline
Old 07-17-2011, 08:57 PM
Admin Emeritus
JasonD's Avatar
Depends on the tuner, but they typically can.
JasonD is offline
Admin Emeritus
JasonD's Avatar
BTW...I am dying to know what you were going to replace the horn with!
JasonD is offline
Old 07-17-2011, 09:39 PM
j.pratt7's Avatar
probly a train horn or just something loud as ****, are you talking about that it would be between the fenderwell and the fender like if I remove the black thing it will be rite there. on which side BTW?
j.pratt7 is offline
Old 07-18-2011, 08:47 AM
Admin Emeritus
JasonD's Avatar
No, I believe it is behind the entire front bumper ("clip"). You have to remove the entire thing to get to the horn.
JasonD is offline
Old 07-18-2011, 04:42 PM
j.pratt7's Avatar
Ok Thx ill check into it.
j.pratt7 is offline
Old 07-19-2011, 07:52 AM
2010_5thgen's Avatar
if you blew a train horn at me i, would probably get out of my car and bash your windows in.
2010_5thgen is offline
Old 07-19-2011, 08:20 AM
Admin Emeritus
JasonD's Avatar
Yes, I have to say that I would feel the same way.
JasonD is offline
Old 07-19-2011, 08:58 AM
ok...glad i wasnt the only one thinking that.
Old 07-25-2011, 09:26 PM
j.pratt7's Avatar
i ended up putting a bad boy horn in it on the passenger side and left the factory on the drivers side, it sounds pretty cool.
which one of these cold air intakes do you think i should you get?
http://www.knfilters.com/search/prod...x?Prod=63-3075
http://www.airaid.com/ProductDetail....ductID=250-242
and also do you think its worth putting this in:
http://www.airaid.com/ProductDetail....ctID=200-630-1
thx, i know its alot.
j.pratt7 is offline
Old 07-25-2011, 09:27 PM
j.pratt7's Avatar
i plan on buying them through autoanything.com
j.pratt7 is offline
Quick Reply: Horn and Programer
