Exhaust: Axle-back or Cat-back
Old 07-28-2011, 10:32 AM
speedracrr6's Avatar
So I finally purchased my first Camaro and I am looking to upgrade the exhaust. I really like the borla systems and looking at the S-Type or the Atak system. My question is - is there any real benefit to doing a Cat-back system over an Axle-back system? Will the Cat-back give a better flow to the system or will an Axle-back be sufficient. I am also adding a K&N CAI and I want to get the best bang for the buck. Thanks for your help.
Also, was wondering how many people have the borla Atak and if it is really loud or not too bad on the inside of the car?
speedracrr6 is offline
Old 07-28-2011, 12:18 PM
2010_5thgen's Avatar
Re: Exhaust: Axle-back or Cat-back
i have the s type catback on my car. if you dont want to buy the whole catback, the axle back will be fine. its the same diameter pipe as the stock anyways(2 1/2").
2010_5thgen is offline
Old 07-28-2011, 03:37 PM
malachi85's Avatar
axel back will work fine...but I prefer the catback for the 5th gens..larger pipes release the aggression a little more.
malachi85 is offline
Old 07-28-2011, 04:11 PM
km9v's Avatar
Cat back w/ x-pipe will flow better than axle back & have a more aggressive sound. Stock has 2 resonators. A cat back will probably give a bit more drone @ hwy speeds.
km9v is offline
Old 07-29-2011, 06:35 AM
the borla is 2 1/2", just like stock. unless he chooses a different company and goes to a 3".
Old 07-29-2011, 12:58 PM
Thanks everyone for the help. I think I am going to go with the Cat-Back system and go middle of the road with the S-Type from Borla. I like the sound of the ATAK but I also like listening to the radio. Appreciate the help.
Old 07-29-2011, 01:45 PM
is the atak louder than the s-type?
Old 07-30-2011, 09:49 AM
WildVettes's Avatar
Another thing to consider is whether or not you plan to do Headers at any point in time. Most header systems have their own X-Pipe and mids. If you plan on going long tubes later on it may be a better idea to just get the axle-back and then get the rest of the piping with the long tubes. Otherwise, you'll probably end up scrapping everything before the Axle-Back anyway.
If you never plan on getting long tubes, spend the extra money on the cat-back.
WildVettes is offline
Old 08-01-2011, 06:44 AM
why would you not be able to use long tubes with a catback? i got my borla catback and then later installed their long tube headers.....never scapped any part of the exhaust. it was meant to go together.
Old 08-02-2011, 08:28 AM
WildVettes's Avatar
The only reason that would work is if you matched catback to headers. Not all header systems are just headers. So for example LG long tube headers give you the x pipe and mids as part of the headers. So if I buy a Borla cat-back and then LG headers I would now have two sets of mids and X Pipes and the ones with the cat-back were not designed to work with the headers.
Not everyone is going to buy headers and a cat-back from the same manufacturer.
Old 08-02-2011, 08:42 PM
Mucker15's Avatar
Is your car an A6 or M6 ? If its an A6 and you do a cat back the afm is going to drive you nuts unless you tune it out, it drove me nuts
The A6 has a giant resonator thats pretty heavy so an Xpipe is a good replacement. If you cars an M6 doing a axle back is fine because the M6 cars come with an H pipe stock. Another option I considered was buying the edelbrock X pipe for $128 its stainless then adding the axle back of your choice, this will save you a few dollars. I have seen the edelbrock its pretty nice and priced pretty cheap afew of my guys have it its sounds the same as my original spintech x and a lot cheaper,
Mucker15 is offline
Old 08-02-2011, 08:46 PM
Mucker15's Avatar
you can try adding a KN filter first before you spend the money on a whole cai, you can always sell the KN on ebay.
Also if you are worried about inside noise the only exhaust I have seen so far that really doesnt drone is the american racing set up
Borla atak sounds insane but it is loud very loud.
also the X will flow better than the res (a6) on the M6 cars the H and the X its a whole other debate but I dont think theres a real noticable difference
this my set up
ARH 1 7/8s headers and 3 inch x pipe spintech axle back,
http://www.youtube.com/watch?v=jJEaS2j0Th8
Mucker15 is offline
Old 08-21-2011, 05:19 PM
WildVettes's Avatar
this my set up
The biggest difference between an H pipe and an X pipe is the way the car reacts under deceleration. With an H pipe you are more likely to get that popping sound under deceleration than with an X pipe. X pipes do flow a little better but you won't be writing home to mom about it. The biggest reason to get the X pipe over H pipe is the improved sound characteristics.
RUENUF
03-13-2016 03:37 PM
marlar98
10-21-2015 02:02 PM
realistyc
07-28-2015 07:32 PM
alphaauto
07-26-2015 04:40 PM
mattman
09-21-2004 02:23 PM
Quick Reply: Exhaust: Axle-back or Cat-back
