DIY - Install BFxenon HID Fog Light kit - RS and non-RS models
Old 12-12-2009, 12:35 PM
BFxenon.com's Avatar
How-To: Install BFxenon HID Fog Lights
When installing BFxenon HID lights, for your safety, please remember to remove the battery terminal / positive lead to the battery before connecting any high voltage parts.
Step 1: Twist and pull to remove factory bulbs from the factory housing
*Step 2 and 3 are for the RS package equipped cars.
Step 2: Remove the black plastic surround, with a flat head screwdriver, by lifting up on plastic tabs.
Step 3: Remove the fog light housing from the bumper by squeezing the tabs and pushing them through the hole that secures them.
Step 4: Insert 5202 BFxenon HID bulbs directly into the housings (housings supplied in RS-Package kits) and secure them in place with the clips on the bulb. Make sure both sides clamp down
Step 5: Remove factory connection and attach the new lead provided
Step 6: Insert new lead into the ballast and connect the two leads on the ballast with the 5202 HID bulb
Step 7: Run the fog light switch into the cab.
*We ran the switch through the fender well and into the wire loom through the door. We had to add about 2’ of wire to accommodate the necessary length.
*You could also run it directly through the firewall by the brake master cylinder.
Step 8: Re-attach the positive battery connection and turn everything on. This is just to ensure everything lights up properly before you secure the ballasts and wires.
Step 9: Secure the HID ballast within the range of the connections so there is no stress on the bulb. Some recommended locations are; firewall, radiator mounting brace, front bumper brace, etc. (Some of these may not be the best option for every vehicle)
Step 10: Secure all the loose wiring away from any moving parts and out of the way of extreme heat.
Step 11: Enjoy your BFxenon HID headlights!
For more information or suggestions on how to make these instructions better, please contact: Sales@BFxenon.com
BFxenon.com is offline
Old 12-13-2009, 07:22 PM
Admin Emeritus
JasonD's Avatar
Is this for your 5th Generation Camaro RS package Fog Light Kit?
JasonD is offline
Old 12-15-2009, 10:34 AM
yes, for the RS, LS, LT packages... whether you have no fog lights or DRL only.
Let me know if you have any questions! Thanks Jason
Jlo
02-03-2015 09:41 PM
alphaauto
01-23-2015 07:42 AM
Brake_L8
01-20-2015 09:44 AM
siguy
11-27-2014 10:07 AM
30thZ286speed
08-03-2002 04:54 AM
Quick Reply: DIY - Install BFxenon HID Fog Light kit - RS and non-RS models
