Go Back   CamaroZ28.Com Message Board > 2010 - 2014 5th Generation Chevrolet Camaro Forums > 2010 - 2014 Camaro Wheels, Tires, Brakes, Suspension
Sign in using an external account
Register Forgot Password?
Reply Post New Thread
LinkBack Thread Tools Search this Thread Display Modes
Old 07-28-2008, 10:05 AM   #1
Tokuzumi's Avatar
What is the bolt pattern size for the new Camaro?
Just curious if these 5th gen wheels are a different bolt pattern than 3rd and 4th gens? Would make a nice upgrade for the older f-bodies.
This ad is not displayed to registered members.
Register your free account today and become a member on CamaroZ28.com!
__________________
Just your basic bolt-ons, and a loudmouth...exhaust
Tokuzumi is offline   Reply With Quote
Old 07-28-2008, 10:24 AM   #2
Admin Emeritus
JasonD's Avatar
Garage
I am not expecting it to be the same as before. Take a look at a C6 or a G8, they might be similar or the same as each other I am thinking that they might be on the Camaro as well. Just a guess.
JasonD is offline   Reply With Quote
Old 07-28-2008, 10:28 AM   #3
Tokuzumi's Avatar
Quote:
C6 wheels pretty much bolt right up to a 4th gen, don't they (based on the sticky in the Wheels and Tires forum)? Minus a little grinding on the inner hub, that is.
Edit: Although, I have not seen any 4th gens with GTO wheels....
__________________
Old 07-28-2008, 12:46 PM   #4
Admin Emeritus
JasonD's Avatar
Garage
Quote:
I don't think it is possible. Not necessarily the bolt pattern, but the offset. I'd like to see what someone with more knowledge on the subject know about it.
Also, see this blog entry.
http://www.camaroz28.com/forums/blogs/jasond-1186/43-what-i-dont-like-about-2010-camaro-one-disciples-point-view/
Old 07-28-2008, 01:56 PM   #5
I am pretty certain the pattern will be the same as the G8. If so there should be plenty of wheel options for those who want something different. I beleive the pattern is the same as the 3 series BMW. If I am correct the pattern will be 5-120
Pruettfan is offline   Reply With Quote
Old 08-03-2008, 07:43 PM   #6
GTO wheels work on 4th gens just fine. You just need to dremel the hub a little bit. The guy who bought my original GTO wheels has them on his TA. Said it took all of 10 minutes to do for all 4 wheels.
The difference in bolt pattern is about the width of a hair. GTO's have been using 4th gen and Vette wheels for quite awhile.
__________________
Rob
04 GTO
08 GXP
RobsWS6 is offline   Reply With Quote
Old 08-03-2008, 07:53 PM   #7
Admin Emeritus
JasonD's Avatar
Garage
Cool! What about the offset? Does it look weird?
Old 08-03-2008, 11:10 PM   #8
Fit wise, it wasn't bad at all. Look wise, I didn't like it. Of course I didn't like the stock 17" wheels on a GTO either.
Stock WS6 wheels fit perfectly on the back of the GTO. The offset is about as perfect as you can get. But you can't run them on the front as they will hit the strut assembly. I had pics of them on almost 4 years ago. Somebody did have 2 WS6 wheels narrowed an inch and it worked out great.
There are a few people that run 16" F-Body wheels without problems.
__________________
Rob
04 GTO
08 GXP
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
Garage Plus vBulletin Plugins by Drive Thru Online, Inc.
