2010 - 2015 Camaro Wheels, Tires, Brakes, Suspension Discussion for 2010 - 2011 - 2012 - 2013 - 2014 - 2015 Chevrolet Camaro Wheels | Tires | Brakes | Suspension
[Brakes] Stainless Steel OEM Fit Brake Hose Kits From J&M Products
Old 05-09-2010, 11:52 AM
Former Vendor
hotpart's Avatar
J&M Products is proud to announce the release of these new direct fit D.O.T. certified Teflon lined brake hoses for the 2010 Camaro. These brake hose assemblies use true OEM style direct replacement non-universal fittings to achieve proper factory hose routing and fitment. Expansion of stock rubber hoses causes a spongy brake pedal feel and loss of initial braking force. Installation of our Teflon-lined stainless steel hose assemblies will give your car a firmer pedal, quicker braking response, and easier brake modulation. Every hose is tested to 3000 psi to guarantee a leak free hose assembly. Best of all these are made by J&M Products right here in the USA.
Benefits:
- Direct OEM fit
- Quicker brake response
- Better brake modulation
- Every hose is pressure tested to 3000 psi
- Every hose is stamped with our Registered U.S. DOT number.
Fits: 2010, 2011 F-body Camaro
hotpart is offline
CARiD
01-14-2015 04:00 AM
SpeedJunkee
12-09-2014 10:17 PM
12-04-2014 11:56 AM
12-01-2014 08:08 AM
The Seer
Classic Engine Tech
11-26-2014 05:55 PM
Quick Reply: [Brakes] Stainless Steel OEM Fit Brake Hose Kits From J&M Products
