2010 - 2015 Camaro Wheels, Tires, Brakes, Suspension Discussion for 2010 - 2011 - 2012 - 2013 - 2014 - 2015 Chevrolet Camaro Wheels | Tires | Brakes | Suspension
[Suspension] Pfadt suspension accommodates GM Manufacturing Change for Camaro
Old 04-26-2010, 03:57 PM
Pfadt Racing's Avatar
Hello all!
It has surfaced recently that there has been an upper spring isolator change for the Camaro, by General Motors. Quite frankly, we didn't see this as a big deal when we heard about it, hence why we never addressed it on the forums like other manufacturers have. We thought everyone had done enough engineering development to have this not be an issue. We just want to let everyone know, that our Pfadt Drop Springs, Coilovers, whatever...has no problem fitting with this recent spring isolator change from GM. Other companies are scampering to get some product revision to the market that accommodates this new part from GM. This means you will need to let them know what year car you have, take off your wheel and see what color isolator you have...makes NO difference to us at all! We just want to know if you have a Camaro!
Bottom line: Pfadt Racing has you covered. All of our springs/coilovers are unaffected by this change. Take a look at the pics below.
New isolator on left, old one on the right
Our Existing Drop Springs Fit Just fine with the new GM part
And, obviously since we discard any isolator in our coilover installation procedure, our coilovers still will work just fine. Our upper spring mount fits on the OEM strut top, which does not change.
Pfadt Racing is offline
Old 04-26-2010, 06:32 PM
Admin Emeritus
JasonD's Avatar
Glad to know what the aftermarket is paying attention to small changes!
JasonD is offline
F'n1996Z28SS
08-23-2023 11:19 PM
Collector Car
01-05-2015 10:58 AM
Quick Reply: [Suspension] Pfadt suspension accommodates GM Manufacturing Change for Camaro
